Noisy Hemi valve train
#1447969
06/05/13 05:00 PM
06/05/13 05:00 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
A friend og mine has an original 66 Hemi-Charger. The current Hemi-engine is a 1965 model, with heads from 1968. The engine has the original mechanical flat tappet cam. According to the service manual the exhaust valve clearance is supposed to be .032, intake .028 These gaps seem fairly big, and they seem to create a noisy valve train. Are these gaps normal and is the valve train normally noisy? Can anything be done to the noise?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Noisy Hemi valve train
[Re: hemi71x]
#1447972
06/05/13 05:40 PM
06/05/13 05:40 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Then why have I heard many quiet Hemis ?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1447973
06/05/13 05:58 PM
06/05/13 05:58 PM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
Thats a good question, i've heard them both ways also. Mine is loud but i have heard some that are louder and some that are quiter?
[Re: hemi71x]
#1447978
06/05/13 07:42 PM
06/05/13 07:42 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Maybe because they are 70-71 hydraulic lifter.
[Re: quickd100]
#1447985
06/06/13 03:21 PM
06/06/13 03:21 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Set the valve lash as specified, you get used to the valve train noise, it's normal. It reminds me of a well oiled sewing machine. If you don't like it turn up the radio. With a cast iron block and aluminum heads the .010/.010 is probably pretty close setting them cold.Dave
Couldn't agree more. I have alum heads and iron block. I started at .016...too noisy. Went to .013....better, but still noisy. .010 did the trick.
Dead quiet when cold, quieter mechanical noise when hot.
[Re: RUNCHARGER]
#1447987
06/07/13 08:31 PM
06/07/13 08:31 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Whats the Problem? All solids make noise to some degree. He can always swap in a hydraulic
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
