Brake light and ABS light is on??? #1446048
06/01/13 02:15 PM
06/01/13 02:15 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
My brakes seem fine on my '06 2500, but the dinger dings, and the lights on the dash board come on as the picture shows below.
Anyone ever have this happen to them??
As always - Thanks Moparts, and thanks to everyone for any advice!!
Wally.
Re: Brake light and ABS light is on??? [Re: wkroncke17] #1446049
06/01/13 03:01 PM
06/01/13 03:01 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Is reservoir full on the master cylinder? Low brake fluid level could cause that without the brakes feeling bad. If you have a compatible scan tool I'm sure there will be a code that will tell you where the problem may be.
Re: Brake light and ABS light is on??? [Re: MPerry] #1446050
06/01/13 03:16 PM
06/01/13 03:16 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Most of the time it's fluid level, could be an issue with the parking brake-not fully released or even a brake light bulb/switch being bad. Usually if both lights are on, it's not an ABS specific issue. HTH, Steve
Re: Brake light and ABS light is on??? [Re: Skeptic] #1446051
06/01/13 04:18 PM
06/01/13 04:18 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
could be a bad speed sensor on the rear axle or trans. typically it is the rear axle sensor.
looks like this...
Re: Brake light and ABS light is on??? [Re: sthemi] #1446052
06/01/13 05:14 PM
06/01/13 05:14 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
front wheel hub sensor on my dakota threw the same code lights.mine ended up being a wire had rubbed through on the harness going to the speed sensor,i replaced the hub sensor and the problem was gone.as above have it scanned to see what codes are present.
Re: Brake light and ABS light is on??? [Re: MPerry] #1446053
06/02/13 12:15 AM
06/02/13 12:15 AM
Wisconsin
Wisconsin
Duh!! I should have checked the fluid first thing!!
I was running to grad partys all day today, I will check that and the fuses tomorrow.
Where would be the best place to get the code read?
Thanks everyone!!
Re: Brake light and ABS light is on??? [Re: wkroncke17] #1446054
06/02/13 12:37 AM
06/02/13 12:37 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
ABS problem trips both lights. Fluid issue would only trip the brake light
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Brake light and ABS light is on??? [Re: wkroncke17] #1446055
06/02/13 12:39 AM
06/02/13 12:39 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
your brakes will work, but with out the anti-lock system.. you will need to start with a scan.. usally a wheel speed sensor or wheel bearing..
Re: Brake light and ABS light is on??? [Re: Dakota_Don] #1446056
06/02/13 08:53 AM
06/02/13 08:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My Durango if the fluid is low it trips both lights.Blew a line and once it was low both lite.Rocky
Chrysler Firepower
Re: Brake light and ABS light is on??? [Re: sreinheimer] #1446057
06/02/13 10:12 AM
06/02/13 10:12 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Wrong
Re: Brake light and ABS light is on??? [Re: Dakota_Don] #1446058
06/02/13 10:13 AM
06/02/13 10:13 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Wrong
Re: Brake light and ABS light is on??? [Re: Skeptic] #1446059
06/02/13 10:51 AM
06/02/13 10:51 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
mine did that and i lifted up the brake pedal with my toe and it went out.
Re: Brake light and ABS light is on??? [Re: bonefish] #1446060
06/02/13 04:33 PM
06/02/13 04:33 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Both lights are on in my 01, but that's because I pulled the abs fuse
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Brake light and ABS light is on??? [Re: Silver70] #1446061
06/05/13 02:58 PM
06/05/13 02:58 PM
Wisconsin
Wisconsin
Well, all of the fuses are ok, the brake fluid level was just a hair low, so I topped it off, and the lights are still on!!
So it must be one of the wheel speed sensors??
Is there one in particular to look for?
Thanks all!!
Re: Brake light and ABS light is on??? [Re: Skeptic] #1446062
06/05/13 03:11 PM
06/05/13 03:11 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Wrong
What part of this is wrong?
Our ABS light just came on and I told the Ole' Girl it was just like her last car now. ABS is for folks that don't know how to drive in slippery conditions... Just like 4 wheel drive for driving on city streets in the winter... Not necessary either. I never had it in any of my stuff, cause I run older stuff, but she wanted something newer. Are we in trouble just because the ABS is out of order? Is there some issue I am not aware of that will make this an unsafe vehicle?
Not trying to be a smart$$ or start an argument. It's just that I have been driving for 35 years and just don't get this make the car smarter than the driver stuff.
I have mechanical Aptitude.
I can screw up anything.
Re: Brake light and ABS light is on??? [Re: sthemi] #1446063
06/05/13 03:27 PM
06/05/13 03:27 PM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
One has to wonder if that differential was serviced regularly....
Re: Brake light and ABS light is on??? [Re: bboogieart] #1446064
06/05/13 03:43 PM
06/05/13 03:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Wrong
ABS light only with a wheel speed sensor or bearing. Both lights come on if both systems are affected. Most cars are more capable of controlling brake lockup than their drivers, snowy conditions excepted.
Re: Brake light and ABS light is on??? [Re: Skeptic] #1446065
06/05/13 08:06 PM
06/05/13 08:06 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx. I can sleep easy.
Re: Brake light and ABS light is on??? [Re: wkroncke17] #1446066
06/07/13 08:42 AM
06/07/13 08:42 AM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
When my '04 Ram 2500 did this it required a $500 ABS module replacement. Completed by dealer 'cause I had no idea how to diagnos. Sometimes you just can't do it all yourself!
Re: Brake light and ABS light is on??? [Re: 74Charger] #1446067
06/10/13 06:28 PM
06/10/13 06:28 PM
Wisconsin
Wisconsin
I replaced the rear ABS sensor yesterday - the lights are still on!!
What next????
Should I just drive it?
