Re: Brake light and ABS light is on???
[Re: Skeptic]
#1446051
06/01/13 04:18 PM
06/01/13 04:18 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
could be a bad speed sensor on the rear axle or trans. typically it is the rear axle sensor. ![](/ubbthreads/images/graemlins/Twocents.gif) looks like this...
[Re: MPerry]
#1446053
06/02/13 12:15 AM
06/02/13 12:15 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Is reservoir full on the master cylinder? Low brake fluid level could cause that without the brakes feeling bad. If you have a compatible scan tool I'm sure there will be a code that will tell you where the problem may be.
Duh!! I should have checked the fluid first thing!! I was running to grad partys all day today, I will check that and the fuses tomorrow. Where would be the best place to get the code read?
Thanks everyone!!
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: wkroncke17]
#1446054
06/02/13 12:37 AM
06/02/13 12:37 AM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
ABS problem trips both lights. Fluid issue would only trip the brake light
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: Dakota_Don]
#1446056
06/02/13 08:53 AM
06/02/13 08:53 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
My Durango if the fluid is low it trips both lights.Blew a line and once it was low both lite.Rocky
Chrysler Firepower
[Re: Dakota_Don]
#1446058
06/02/13 10:13 AM
06/02/13 10:13 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
your brakes will work, but with out the anti-lock system.. you will need to start with a scan.. usally a wheel speed sensor or wheel bearing..
Wrong
[Re: bonefish]
#1446060
06/02/13 04:33 PM
06/02/13 04:33 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Both lights are on in my 01, but that's because I pulled the abs fuse ![](/ubbthreads/images/graemlins/laugh2.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1446061
06/05/13 02:58 PM
06/05/13 02:58 PM
wkroncke17
Wisconsin
Well, all of the fuses are ok, the brake fluid level was just a hair low, so I topped it off, and the lights are still on!! So it must be one of the wheel speed sensors?? Is there one in particular to look for? Thanks all!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: bboogieart]
#1446064
06/05/13 03:43 PM
06/05/13 03:43 PM
Skeptic
The Pale Blue Dot
Wrong
What part of this is wrong? Our ABS light just came on and I told the Ole' Girl it was just like her last car now. ABS is for folks that don't know how to drive in slippery conditions... Just like 4 wheel drive for driving on city streets in the winter... Not necessary either. I never had it in any of my stuff, cause I run older stuff, but she wanted something newer. Are we in trouble just because the ABS is out of order? Is there some issue I am not aware of that will make this an unsafe vehicle? Not trying to be a smart$$ or start an argument. It's just that I have been driving for 35 years and just don't get this make the car smarter than the driver stuff.
ABS light only with a wheel speed sensor or bearing. Both lights come on if both systems are affected. Most cars are more capable of controlling brake lockup than their drivers, snowy conditions excepted. ![](/ubbthreads/images/graemlins/Twocents.gif)
