Re: do dynomax super turbos drone at cruising speed?
[Re: RSNOMO]
#1441367
05/24/13 01:42 PM
05/24/13 01:42 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Hooker's into 2.5" pipe, with balance tube...
Old, loud, Flowmaster's...With insulated trunk divider...
No drone...
Are flomasters made by dynomax now ?
[Re: JohnRR]
#1441368
05/24/13 02:04 PM
05/24/13 02:04 PM
Challenger 1
Cincinnati, Ohio
No drone...
[Re: topside]
#1441369
05/24/13 02:40 PM
05/24/13 02:40 PM
Posts: 965 S.W. Pennsylvania
markrr
S.W. Pennsylvania
I've had them on 2 cars so far with 2.5" full exhaust using an H-pipe, and no drone. Sound crisp, nice tone, not too loud at idle or cruise.
There must be something different about your systems that keep it from droning.
[Re: markrr]
#1441370
05/24/13 02:45 PM
05/24/13 02:45 PM
Challenger 1
Cincinnati, Ohio
I run the super turbos with headers and a H pipe, no drone. I think it has to do with stock exhaust manifolds or no H pipe. But I think stock exhaust manifolds are more the reason they drone, JMO from reading here.
[Re: cudabitten]
#1441373
05/24/13 03:08 PM
05/24/13 03:08 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if they do drone (depends a lot on pipe geometry, diameter, and muffler placement), some glasspacks in the tails as resonators will eliminate it
the further back you can get the mufflers, reducing tailpipe length, the less you'll have drone
[Re: patrick]
#1441375
05/24/13 03:27 PM
05/24/13 03:27 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Depends on more than just what muffler you run, like pipe size, x-pipe, h-pipe, no cross pipe, length of muffler body, where muffler is from front to back, headers, what size headers, no headers, engine size, horse power...on and on.
I run the long case Dynomax Super Turbos with no drone at cruise. However I do get a slight drone at 1,600 RPM and at 2,100 RPM. But at speed it doesn't bother me. On the road I usually am running at 2,700 RPM and higher. Have fun.
[Re: cudabitten]
#1441376
05/24/13 04:45 PM
05/24/13 04:45 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Isn't the noise coming from the outside of the car?
Absolutely...
But, you're hearing it from inside...
[Re: 72blubird]
#1441379
05/24/13 07:32 PM
05/24/13 07:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Run Super Turbos on my old stuff. Never ran headers or an H pipe. No drone. No steep gears either. Steepest gear I ever ran with Super Turbos is 3.23's.
