do dynomax super turbos drone at cruising speed? #1441362
05/24/13 12:17 PM
05/24/13 12:17 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Ive heard you guys say good stuff about these mufflers, how are they while cruising?
Re: do dynomax super turbos drone at cruising speed? [Re: cudabitten] #1441363
05/24/13 12:28 PM
05/24/13 12:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have the short case mufflers on my dart , stock manifolds , 2.5 mandrel bent pipes , no H or X ... it drones at cruising speed with 3.91's
Re: do dynomax super turbos drone at cruising speed? [Re: JohnRR] #1441364
05/24/13 12:41 PM
05/24/13 12:41 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I have stock manifolds, 2.5" pipes, a crossover pipe and, 3.54 gears and mine drones.
Re: do dynomax super turbos drone at cruising speed? [Re: cudabitten] #1441365
05/24/13 12:58 PM
05/24/13 12:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Hooker's into 2.5" pipe, with balance tube...
Old, loud, Flowmaster's...With insulated trunk divider...
No drone...
Re: do dynomax super turbos drone at cruising speed? [Re: RSNOMO] #1441366
05/24/13 01:10 PM
05/24/13 01:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had them on 2 cars so far with 2.5" full exhaust using an H-pipe, and no drone. Sound crisp, nice tone, not too loud at idle or cruise.
Re: do dynomax super turbos drone at cruising speed? [Re: RSNOMO] #1441367
05/24/13 01:42 PM
05/24/13 01:42 PM
JohnRR Offline
JohnRR  Offline
No drone...
Are flomasters made by dynomax now ?
Re: do dynomax super turbos drone at cruising speed? [Re: JohnRR] #1441368
05/24/13 02:04 PM
05/24/13 02:04 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No drone...
Re: do dynomax super turbos drone at cruising speed? [Re: topside] #1441369
05/24/13 02:40 PM
05/24/13 02:40 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
There must be something different about your systems that keep it from droning.
Re: do dynomax super turbos drone at cruising speed? [Re: markrr] #1441370
05/24/13 02:45 PM
05/24/13 02:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
I run the super turbos with headers and a H pipe, no drone. I think it has to do with stock exhaust manifolds or no H pipe. But I think stock exhaust manifolds are more the reason they drone, JMO from reading here.
Re: do dynomax super turbos drone at cruising speed? [Re: Challenger 1] #1441371
05/24/13 02:51 PM
05/24/13 02:51 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I run dual 3" Super Turbos on my Dually440, headers and no h pipe. No drone even under heavy towing loads,but they do get pretty loud at that point. I agree that manifolds are the main issue inducing drone with them.
Keith
Re: do dynomax super turbos drone at cruising speed? [Re: Challenger 1] #1441372
05/24/13 02:54 PM
05/24/13 02:54 PM
eastern, pa.
eastern, pa.
Thanks, I already purchased headers, maybe I'll look into an " H" pipe? I am starting from scratch this is my first build. I just remember from back in the day cruising in some of my friends cars at first the drone was fun but after a while it was stupid.
I'm not sure the insulated divider would do anything? Isnt the noise coming from the outside of the car?
Re: do dynomax super turbos drone at cruising speed? [Re: cudabitten] #1441373
05/24/13 03:08 PM
05/24/13 03:08 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if they do drone (depends a lot on pipe geometry, diameter, and muffler placement), some glasspacks in the tails as resonators will eliminate it
the further back you can get the mufflers, reducing tailpipe length, the less you'll have drone
2017 Grand Cherokee Overland
Re: do dynomax super turbos drone at cruising speed? [Re: patrick] #1441374
05/24/13 03:09 PM
05/24/13 03:09 PM
the house on the left.
cogen80 Offline
cogen80  Offline
depends on the car.
seems to me that cars running manifolds (crossover or not) drone with the super turbos more then the cars running headers for some reason.
Re: do dynomax super turbos drone at cruising speed? [Re: patrick] #1441375
05/24/13 03:27 PM
05/24/13 03:27 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Depends on more than just what muffler you run, like pipe size, x-pipe, h-pipe, no cross pipe, length of muffler body, where muffler is from front to back, headers, what size headers, no headers, engine size, horse power...on and on.
I run the long case Dynomax Super Turbos with no drone at cruise. However I do get a slight drone at 1,600 RPM and at 2,100 RPM. But at speed it doesn't bother me. On the road I usually am running at 2,700 RPM and higher. Have fun.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: do dynomax super turbos drone at cruising speed? [Re: cudabitten] #1441376
05/24/13 04:45 PM
05/24/13 04:45 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Isn't the noise coming from the outside of the car?
Absolutely...
But, you're hearing it from inside...
Re: do dynomax super turbos drone at cruising speed? [Re: RSNOMO] #1441377
05/24/13 06:03 PM
05/24/13 06:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
No drone here but too loud to suit me.Complete 3" TTI from Max Wedge manifolds back with Super Turbo's.
Re: do dynomax super turbos drone at cruising speed? [Re: 62maxwgn] #1441378
05/24/13 06:33 PM
05/24/13 06:33 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
I get a drone around 45 then it goes away immediately after or before.My system is 2.5" tti with H pipe through factory manifolds. I really love the sound of the system
What was I thinking....
Re: do dynomax super turbos drone at cruising speed? [Re: 72blubird] #1441379
05/24/13 07:32 PM
05/24/13 07:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Run Super Turbos on my old stuff. Never ran headers or an H pipe. No drone. No steep gears either. Steepest gear I ever ran with Super Turbos is 3.23's.
Don't be the exception.
Re: do dynomax super turbos drone at cruising speed? [Re: Supercuda] #1441380
05/25/13 12:29 AM
05/25/13 12:29 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Wow, talking about getting a good read. Some of you guys say yea yea drone, others say no drone. Im having a hard time believing stock exhaust manifolds will make the system drone. If anything headers would. In either case, there seems to be no agreement between those here.
Re: do dynomax super turbos drone at cruising speed? [Re: gomangoRTSE] #1441381
05/25/13 12:36 AM
05/25/13 12:36 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Depends on the total system.
You are dealing with noise damping with different size and length pipe AND air flow. All connected to different engines at different RPMs.
Even the factory used resonators in a lot of cases and they would have gladly not spent the time/money on them if not needed.
