Re: 1969 Superbee trunk lid fit issues
[Re: 52savoy]
#1435031
05/13/13 07:59 AM
05/13/13 07:59 AM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
If you haven't tried it yet, you can adjust the catch thats bolted in the floor left or right to pull the lid to the right or left.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
[Re: 52savoy]
#1435032
05/13/13 09:29 AM
05/13/13 09:29 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Have you gave the lid a few good tugs(jerks) to the right? That's the only way I know of.
Exactly the way to "adjust" it left or right, open the lid, and rack it over to the "offending" side by shoving it hard...
[Re: bobbyb]
#1435033
05/13/13 10:32 PM
05/13/13 10:32 PM
Posts: 374 New York
Mopucky
New York
We tried that and it works but the lid is hard to latch and release. I guess last ditch effort this will work.
[Re: DAYCLONA]
#1435034
05/13/13 10:34 PM
05/13/13 10:34 PM
Posts: 374 New York
Mopucky
New York
We tried this, will try again, it acts as if we'll hurt it going too far. Thanks for the input!
[Re: notforsale440]
#1435036
05/14/13 08:15 AM
05/14/13 08:15 AM
bobbyb
New Kent, Va.
I had the same problem with a challenger lid and my next door neighbor who is a body repairman said he could fix it but I might not want to be there when he does. So apparently they do get a little physical with them.
[Re: bobbyb]
#1435037
05/14/13 09:26 AM
05/14/13 09:26 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Yeap, that's what I tell some customers watching me do panel alignment, hoods, trunk lids sometimes need to be "racked" hard to align them, 68-70 B body doors, usually have a gap top or bottom when closed when viewed from the rear qtr, the only fix is to either man handle the doors top and bottom while open, and actually give it a twisting jerk to rack the door into shape, some guys will use a block of wood, and slam the door against the jamb,...you can't be afraid of racking a panel to make it "behave"
