1969 Superbee trunk lid fit issues #1435029
05/12/13 12:13 PM
05/12/13 12:13 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
I'm having a hard time setting up my trunk lid before paint. The lid sits too far to the left, there is no adjustment for right and left. My question is, Has anyone tweaked or bent the hinges to make an adjustment? Is this a good repair or should I look for a different set of hinges? They are off the car and the pivot holes look ok. Thanks for the help!
Re: 1969 Superbee trunk lid fit issues [Re: Mopucky] #1435030
05/12/13 12:22 PM
05/12/13 12:22 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Have you gave the lid a few good tugs(jerks) to the right? That's the only way I know of.
Re: 1969 Superbee trunk lid fit issues [Re: 52savoy] #1435031
05/13/13 07:59 AM
05/13/13 07:59 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
If you haven't tried it yet, you can adjust the catch thats bolted in the floor left or right to pull the lid to the right or left.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 1969 Superbee trunk lid fit issues [Re: 52savoy] #1435032
05/13/13 09:29 AM
05/13/13 09:29 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Exactly the way to "adjust" it left or right, open the lid, and rack it over to the "offending" side by shoving it hard...
Re: 1969 Superbee trunk lid fit issues [Re: bobbyb] #1435033
05/13/13 10:32 PM
05/13/13 10:32 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
We tried that and it works but the lid is hard to latch and release. I guess last ditch effort this will work.
Re: 1969 Superbee trunk lid fit issues [Re: DAYCLONA] #1435034
05/13/13 10:34 PM
05/13/13 10:34 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
We tried this, will try again, it acts as if we'll hurt it going too far. Thanks for the input!
Re: 1969 Superbee trunk lid fit issues [Re: Mopucky] #1435035
05/13/13 11:28 PM
05/13/13 11:28 PM
nj
N
notforsale440 Offline
N
nj
get a little rough with it....... now is the time, don't wait till its painted
Re: 1969 Superbee trunk lid fit issues [Re: notforsale440] #1435036
05/14/13 08:15 AM
05/14/13 08:15 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I had the same problem with a challenger lid and my next door neighbor who is a body repairman said he could fix it but I might not want to be there when he does. So apparently they do get a little physical with them.
Re: 1969 Superbee trunk lid fit issues [Re: bobbyb] #1435037
05/14/13 09:26 AM
05/14/13 09:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yeap, that's what I tell some customers watching me do panel alignment, hoods, trunk lids sometimes need to be "racked" hard to align them, 68-70 B body doors, usually have a gap top or bottom when closed when viewed from the rear qtr, the only fix is to either man handle the doors top and bottom while open, and actually give it a twisting jerk to rack the door into shape, some guys will use a block of wood, and slam the door against the jamb,...you can't be afraid of racking a panel to make it "behave"
