Slow me down!?!? #1429185
05/02/13 01:20 PM
05/02/13 01:20 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Will launching the car in second gear (or third) hurt the transmission?
I’m trying to slow the car down about a second for a few races to run in sportsman (12.0 and slower dial)…my car runs 10.80’s normally. I can add enough weight to the car to make it run a between 10.95 and 11.00, so this is my thought to get that last second:
Launch the car in second gear (~0.4 seconds)…or possibly launch in 3rd (not sure what that would do).
Remove the carburetor's secondary linkage so it can’t open (~0.3 seconds).
Retard timing 7 degrees to 27° total (~0.3 seconds).
So, do the times for each suggestion sound about right for slowing the car down?
Does this sound like it would work, and will any of this possibly hurt the motor or trans (this is my MAIN concern)???
Any help, or previous experience with trying any of these is appreciated, thanks!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Slow me down!?!? [Re: FlyFish] #1429186
05/02/13 01:30 PM
05/02/13 01:30 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Why cant you use a throttle limiter or a rev limiter? Seems easier. If you shift at 6k shift at 5k, instead of wide open, 3/4 throttle. Something like that
Re: Slow me down!?!? [Re: FlyFish] #1429187
05/02/13 01:37 PM
05/02/13 01:37 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I have left in 2nd footbrake racing. I went from 10.90's to 11.50's. Really did not change the mph. A good friend of mine builds mopar race trans for a living and didn't advise me against it. It was hard for me to cut a light without deep staging.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Slow me down!?!? [Re: FlyFish] #1429188
05/02/13 01:45 PM
05/02/13 01:45 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
I use this… http://www.etgenie.com/
It’s a little expensive. But it is easily adjustable and capable of constantly being fine-tuned to hit whatever number. I need to slow my car down from 10.9 to 11.5 (no roll bar) and it works fine for me.
There is another place that makes changeable restrictor plates that is cheaper.
This post is available in double vision where drunk.
Re: Slow me down!?!? [Re: FlyFish] #1429189
05/02/13 02:38 PM
05/02/13 02:38 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
We use a Moroso throttle stop,if its on a holley carburator.about $30
Section 8 Racing We are nuts about racing.
Re: Slow me down!?!? [Re: Mopar-Al] #1429190
05/02/13 02:40 PM
05/02/13 02:40 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Yeah, I tried making a home made throttle stop for the carb....Long story, but the short version is FAIL.
My converter flashes to 5000 and I normally shift ~6200, shifting early doesn't do much (runs close to the same). My car runs 0.04 quicker in the 1/8 if I shift at 6500 instead of 6000. I guess I could try shifting at 5500 and see what that does. Going to hit a test-n-tune in the next week or 2 to get this sorted out.
Re: Slow me down!?!? [Re: bwdst6] #1429191
05/02/13 02:44 PM
05/02/13 02:44 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
That ET Genie looks SWEET, but this is just for a few races so I don't want to drop a ton of money on anything.
Re: Slow me down!?!? [Re: bentwheel43] #1429192
05/02/13 02:48 PM
05/02/13 02:48 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Yeah, my home made version sucked big time, I might have to break down and buy one of these eventually. I'm hoping to be able to shave the second off the car with no money spent...but this is definitely a good plan B.
Re: Slow me down!?!? [Re: FlyFish] #1429193
05/02/13 02:53 PM
05/02/13 02:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My son had to slow his up from 10.50's to 11.50's before he had a cage put in. He disconnected the secondaries on his 750 doublepumper and wire tied them shut. He then added 200 pounds of lead to the car and lowered his shift point down from the usual 6400 till he found the needed number. The car still reacted very nice on the tree.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Slow me down!?!? [Re: pittsburghracer] #1429194
05/02/13 03:39 PM
05/02/13 03:39 PM
Guitar Jones Offline
Just tie an old FE Ford engine to the rear bumper, that should do the trick.
Re: Slow me down!?!? [Re: Guitar Jones] #1429195
05/02/13 03:53 PM
05/02/13 03:53 PM
PA.
"Little"John
"Little"John
PA.
Either that or put a HEMI in it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Slow me down!?!? [Re: FlyFish] #1429196
05/02/13 03:54 PM
05/02/13 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a production throttle cable slide it
forward so you only get part throttle.... this is
what I made for my dom... I slow it down just over
1 second for the 10.0 stuff... plus I lower the launch
rpm and the shift rpm
Re: Slow me down!?!? [Re: MR_P_BODY] #1429197
05/02/13 03:58 PM
05/02/13 03:58 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I tried moving my throttle cable a little over an inch a few weeks back...only slowed by 0.3 seconds for some weird reason.
Re: Slow me down!?!? [Re: Mopar-Al] #1429198
05/02/13 04:05 PM
05/02/13 04:05 PM
TN
SCATPACK 1 Online content
SCATPACK 1  Online Content
TN
When you tried to adjust the throtle cable, did you look to see how much it actually limited the carb from opening? Did you try a stiffer return spring on your carb. I did this once and it did not slow the carb down until I put on a stiffer return spring. Maybe the air was blowing the butterflies open even with the cable adjusted out. Did you try to shift 1500 rpm or 2000 RPM lower.
Re: Slow me down!?!? [Re: FlyFish] #1429199
05/02/13 04:07 PM
05/02/13 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You will be suprized at how little the throttle will
be open to slow it 1 second... I'm at 1/3 throttle
and launch at 3600 rpm and shift at 5600
Re: Slow me down!?!? [Re: FlyFish] #1429200
05/02/13 07:23 PM
05/02/13 07:23 PM
Lehigh Acres, Florida
rickstershemi Offline
just fender race'm
Rickster
Re: Slow me down!?!? [Re: rickstershemi] #1429201
05/02/13 07:51 PM
05/02/13 07:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I'd try this first, It's not cheap...it's FREE!
Disconnecting the secondaries and short shift to fine tune the number.
We tried this device to go from 10.20's to 12.0's and got close...11.77...LOL!
http://www.restrictorplate.com/index.html
Re: Slow me down!?!? [Re: pittsburghracer] #1429202
05/02/13 08:40 PM
05/02/13 08:40 PM
fresno ca
mikeysmopars Offline
fresno ca
can't believe the Hemi guys here havn't keypad whipped you to death yet!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Slow me down!?!? [Re: mikeysmopars] #1429203
05/02/13 09:51 PM
05/02/13 09:51 PM
PA.
"Little"John
"Little"John
PA.
They are still at the car shows impressing people with their hoods up. They will be here soon.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Slow me down!?!? [Re: FlyFish] #1429204
05/02/13 09:54 PM
05/02/13 09:54 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
I have posted this pic a few times now. It is a cheap way of slowing you car down without changing your throttle cable position.With this little spacer the more holes between the cable and the carb lever the slower you will go.
