1997 Dodge Ram 2500 Brake Light Problem #1421450
04/17/13 08:51 PM
04/17/13 08:51 PM
Big Wonderful Wyoming!
toomanymopars Offline OP
1997 Ram 2500 Brake lights don't work. The 3rd brake light on the cab does work.
Turnsignals and taillights work.
All fuses and bulbs are good.
Any suggestions?
Is the 3rd brakelight on the same circuit as the regular brake lights? thanks
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: toomanymopars] #1421451
04/17/13 09:16 PM
04/17/13 09:16 PM
Any suggestions?
On the older stuff if the TS lights work but the brakes lights do not then from the connector behind the drivers kick panel rearward from there you are OK & the problem is upstream from there (from that connector back to the TS harness under the colume and the TS switch assy itself & the white wire from the brake light switch. Not sure how much of this applies to your app. Does www.mymopar.com have wiring diagrams for that new of stuff?
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: toomanymopars] #1421452
04/17/13 10:27 PM
04/17/13 10:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The third brake light is not on the same circuit as the brake lights. Double check the fuses.
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: toomanymopars] #1421453
04/18/13 09:51 PM
04/18/13 09:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just looked in my manual. With the third brake light working the fuse is good and the brake switch is working. If you have power at the white with a tan tracer feeding the multifunction switch than the problem is in the turn signal switch. Do the 4 way emergency flashers work? If not make sure that switch is off. Sometimes they can cause odd operation.
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: toomanymopars] #1421454
04/18/13 09:58 PM
04/18/13 09:58 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Any suggestions?
simplest thing to do is trace the circuit with a digital volt meter. Could be as simple as a bad ground
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: VincentVega] #1421455
04/18/13 10:11 PM
04/18/13 10:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Any suggestions?
Ground is not the cause. He has rear turn signal so the circuit is complete. He just has to verify the 4 way flasher and power on the white with tan tracer.
Re: 1997 Dodge Ram 2500 Brake Light Problem [Re: NITROUSN] #1421456
04/18/13 11:30 PM
04/18/13 11:30 PM
This is my son's truck and he is distracted at the moment with his wife having a baby. He did tell me that four way flashers have always been goofy and thinks that possibly the switch could be on.....
I will let you guys know...thanks
