Any suggestions?
On the older stuff if the TS lights work but the brakes lights do not then from the connector behind the drivers kick panel rearward from there you are OK & the problem is upstream from there (from that connector back to the TS harness under the colume and the TS switch assy itself & the white wire from the brake light switch. Not sure how much of this applies to your app. Does www.mymopar.com have wiring diagrams for that new of stuff?
