Who gave up on Ceramic coating?? #1417236
04/09/13 08:42 AM
04/09/13 08:42 AM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
My headers ceramic coating has flaked off. Has anyone just painted over with good results or is it just better to have them coated again??
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417237
04/09/13 10:39 AM
04/09/13 10:39 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You can buy touch up paint to make them look better, but to recoat them they have to remove the coating that is on there and start over.
2011 Drag Pak Challenger
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417238
04/09/13 10:49 AM
04/09/13 10:49 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
How long do you want it to last and what do you want it to look like?
I have touched up the upper part of the tubes with okay success, but have had no luck with the lower tubes and collectors. Especially if any rust has started.
Master, again and still
Re: Who gave up on Ceramic coating?? [Re: DaveRS23] #1417239
04/09/13 12:32 PM
04/09/13 12:32 PM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
did you use heat paint or is there a special type ceramic paint i can buy??
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417240
04/09/13 01:12 PM
04/09/13 01:12 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Who made the headers? The metal obviously was not prepped. Poor workmanship seems to be th norm these days!!
Re: Who gave up on Ceramic coating?? [Re: babarracuda] #1417241
04/09/13 07:18 PM
04/09/13 07:18 PM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
They are Spitfire headers that i bought from Harold, and i had them coated by Fireball coatings in Ontario Canada. They started to dis-color immediatly after i put them on the car. The coating is about 7 years old now but i thought ceramic coating was a one time thing.
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417242
04/09/13 07:27 PM
04/09/13 07:27 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Mine look great after 5 years. I'd tell Harold that his supplier sucks.
Re: Who gave up on Ceramic coating?? [Re: babarracuda] #1417243
04/09/13 09:00 PM
04/09/13 09:00 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Just bought TTIs full polish and inside coated too... The motor is broken in and runs good. Fingers crossed for good results
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417244
04/10/13 02:34 AM
04/10/13 02:34 AM
Detroit, MI
CCPcoatings.com Offline
Detroit, MI
Unfortunately, what you're describing is NOT the fault of the ceramic. Immediate dulling and subsequent "flaking" are indicative of catastrophic failure. I.e., you did something wrong. It only takes minutes but somehow you ran it "too lean" or "too fat". Outside of a component failure, this typically results from starting a new, un-tuned engine with your freshly coated headers, or perhaps a dyno run... Another source for failure is bright ceramic on a turbo or supercharged application. A definite NO NO..... These applications and many others require a "High Temp Ceramic" which is rated much higher at 2000F+. It's almost impossible to hurt these without totally destroying an engine first.
The reality of bright ceramic coatings is this, on a properly tuned engine they will last indefinitely. Make a mistake and you'll see it immediately.
It sounds like either Marc didn't teach how to care for your coated headers or you had a mechanical issue. Did you opt for his ID coating as well? Please post some pics and background on the application and I'll I'll tell you how to fix it going forward.
Below are a few samples of some similar problems.
Re: Who gave up on Ceramic coating?? [Re: CCPcoatings.com] #1417245
04/10/13 09:12 AM
04/10/13 09:12 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Although this is a bit late to help your on going problem. I thought I'd chime in. I had my headers Titanium coated at a powder coating shop. I've run the dog poo poo out of them. Six, seven years old now. Still look great! They started out a little lighter than they are now, but it only looks better now. They look a bit dull in this pic. But they show fantastic! This was when I was removing my motor to prep the engine bay for painting.
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417246
04/10/13 09:59 AM
04/10/13 09:59 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
VHT 1500 Ceramic. Pretty good stuff for rattle can.
I have eventually had problems with all the coatings on all my headers including Hooker's ceramic coating.
With one exception; CCP Coatings out of Michigan. It looked different out of the box. Slicker and shinier than any of the others, more like what I think ceramic should look like. All the others looked somewhat duller and rougher in texture.
CCP is all I intend to use in the future.
One thing I always do on start-up is to have a cheap Harbor Freight laser temp gun in hand. I use it for more than the headers.
Re: Who gave up on Ceramic coating?? [Re: DaveRS23] #1417247
04/10/13 03:57 PM
04/10/13 03:57 PM
Detroit, MI
Detroit, MI
What color did you use?
Re: Who gave up on Ceramic coating?? [Re: babarracuda] #1417248
04/10/13 04:05 PM
04/10/13 04:05 PM
Detroit, MI
Detroit, MI
The fact that the headers dulled almost immediately pretty much negates any potential issue with prep. A prep issue will generally surface rather quickly as a chip, bubble, run etc. Beyond that, most failures come down to improper application / usage.
Re: Who gave up on Ceramic coating?? [Re: CCPcoatings.com] #1417249
04/10/13 08:57 PM
04/10/13 08:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Silver. They are easily the best looking coated headers I have ever had. But then that isn't saying much.
Your coating just looks slicker and smoother than the other company's coatings I have had. And that includes Hooker's, which lasted all of 5 years or so.
And CCP thought that the shipping back to me was too high. So they re-boxed the headers to save some size and saved me several dollars of shipping. Without being asked to.
Thanks guys!
Re: Who gave up on Ceramic coating?? [Re: Mopar2ya] #1417250
04/10/13 09:51 PM
04/10/13 09:51 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I just had my TTI headers ceramic coated by Sanderson (a well known comapny) and they lasted a whole couple of days untill it fell off too.
