Page 3 of 3 1 2 3
Re: block porn continued [Re: pittsburghracer] #1399914
03/15/13 10:16 PM
03/15/13 10:16 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
i'm trying.
Re: block porn continued [Re: rickraw] #1399915
03/15/13 10:20 PM
03/15/13 10:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
i'm trying.
I already have the first to test n tune races lined up helping some guys I did some heads and intakes for. I love test n tune nights.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: block porn continued [Re: Hitman340] #1399916
03/16/13 10:36 AM
03/16/13 10:36 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Looks Nice, I hope to have mine that far along real soon.
Excuse me for being ignorant but what are the extra holes in the oil pan rail for?
Is it the same down the right side pan rail also?
Re: block porn continued [Re: roadhazard] #1399917
03/16/13 10:44 AM
03/16/13 10:44 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
That's pattern they used for drysump pans in craftsman trucks.
Re: block porn continued [Re: W5DART66] #1399918
03/16/13 09:59 PM
03/16/13 09:59 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
WOW. That is way too nice to get dirty. Just put it in the Living room so you can look at it everyday.
Garth
Re: block porn continued [Re: W5DART66] #1399919
03/17/13 10:42 AM
03/17/13 10:42 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Brett
Re: block porn continued *DELETED* [Re: roadhazard] #1399920
03/18/13 10:27 PM
03/18/13 10:27 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Post deleted by Hitman340
Re: block porn continued [Re: Hitman340] #1399921
03/18/13 10:31 PM
03/18/13 10:31 PM
PA.
"Little"John
"Little"John
PA.
Looks like a 10 minute job with a carbide burr and then hit with a sanding roll. Good as new.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: block porn continued [Re: Hitman340] #1399922
03/18/13 11:21 PM
03/18/13 11:21 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Ok, Ran into a little set back.I would just like to ask how many of you have had to deal with in a R3 or Ritter block. The aera im pointing to has not been michined to a large enough radius in order for the crank to clear. Or in my case will not even set down on the bearing surface.All input is welcome. Rick I think you may have all the answers I may need.
Not to worry,I had the same problem with my R3. As John already stated,15 minutes with a die grinder you should be okay. The only PITA is that if you already scrubbed the block you are going to have to do it all over again. Metal shavings from a die grinder seem to find their way everywhere.
Re: block porn continued [Re: Hitman340] #1399923
03/19/13 12:04 AM
03/19/13 12:04 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
where is the step cut in the block for the thrust main bearing
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: block porn continued [Re: pittsburghracer] #1399924
03/19/13 12:05 AM
03/19/13 12:05 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Same here Jeff!!
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: block porn continued [Re: 440W8 Duster] #1399925
03/19/13 12:08 AM
03/19/13 12:08 AM
PA.
"Little"John
"Little"John
PA.
Don't feel to bad. I had my Keith Black 572 cleaned and ready to assemble and found out I had about 4 hours of grinding to do for pushrod clearance on the block.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: block porn continued [Re: WHITEDART] #1399926
03/19/13 12:13 AM
03/19/13 12:13 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think I might see it now.is it that wide cut
Re: block porn continued [Re: pittsburghracer] #1399927
03/19/13 12:23 PM
03/19/13 12:23 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The site glass is a pretty novel idea,,I like that.
Re: block porn continued [Re: Hitman340] #1399928
03/19/13 06:16 PM
03/19/13 06:16 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Hitman. ur block doesn't look like it was machined for a thrust bearing in that pic?? everyone one with a ritter block, feel free to call me with any questions, i have everything fiqured out on this block that needs checked. call after 9:00 pm eastern time. thanks. 724-266-0601.
Page 3 of 3 1 2 3
