Anyone know much about ceramic coating headers? #1395583
03/01/13 03:28 PM
03/01/13 03:28 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I just had my TTI headers re-ceramic coated by local company who makes and sells headers.
The issue is that the ceramic coating is falling off the upper tubes where they meet the heads.
You can just rub your hands across the tubes and it flakes off.
I paid extra to have them first shoot in silver and then in black as they required for dong the black finish.
I just called them and the owner said it's due to my carburetor being getting far to rich and running to hot.
I disagreed as #1 the header never did that with the factory coating and I just had it checked by the guy who tuned the carburetor last time and his meter showed it was not too rich running.
I told them this but they still insist the header tubes are getting too hot and it's not their problem.
So I think it is their fault somehow for maybe not putting the base coat of silver on first.
Anyone have an experiences with this sort of thing? Just wanted to see if their explanation is truthful?
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395584
03/01/13 03:41 PM
03/01/13 03:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Ceramic coating warranty voided in the event of an out-of-tune carburetor'...
Wow...
Re: Anyone know much about ceramic coating headers? [Re: RSNOMO] #1395585
03/01/13 03:55 PM
03/01/13 03:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow...
TTI warns you of this when you buy their headers.
I screwed mine up by doing this to mine when they were new, wish I would have tuned my 440 with old headers first. I did not have enough timing when I broke in my cam and fried the coating right by the flanges. My bad and am living with it. I actually burnt a hole/ crack in one of my headers, took it off and welded it back up from the cam break in.
Other than that I don't have anything else to add. Good luck Stu.
web page
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395586
03/01/13 04:08 PM
03/01/13 04:08 PM
California
mickm Offline
mickm  Offline
California
just had mine done by the same people, (i'm assuming).
i know my engine isn't too lean, so we'll see what happens. mine are silver though, not the second coating of black.
Re: Anyone know much about ceramic coating headers? [Re: RSNOMO] #1395587
03/01/13 04:08 PM
03/01/13 04:08 PM
Wow...
Really.....??? I can understand if the headers were glowing red from way over richened settings, but if that was true why didnt the original TTI coating fall off ater 10 years of use.
Re: Anyone know much about ceramic coating headers? [Re: mickm] #1395588
03/01/13 04:10 PM
03/01/13 04:10 PM
Yes let me know Mick how they hold up.
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395589
03/01/13 05:16 PM
03/01/13 05:16 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
The headers wouldn't turn red from a rich condition. That is caused by running lean.
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395590
03/01/13 05:22 PM
03/01/13 05:22 PM
fresno ca
mikeysmopars Offline
fresno ca
CAPS COATING, In Fresno Ca did mine and i love them. $275.00
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Anyone know much about ceramic coating headers? [Re: mikeysmopars] #1395591
03/01/13 05:34 PM
03/01/13 05:34 PM
alberta
Publicbottle Offline
alberta
Can damage to the coatings be caused just during idling? How long does it take to do permanent damage if too rich/lean?
Re: Anyone know much about ceramic coating headers? [Re: Publicbottle] #1395592
03/01/13 05:43 PM
03/01/13 05:43 PM
fresno ca
fresno ca
I would assume if it was Real lean they could discolor but mine are open so no real threat there. If you want to talk to the people who did mine call them ask about warranty and details.
CAPS BRITE HOT COATINGS
FRESNO CA TOLL FREE # 877-647-2628
OR www.capsbhc.com
Re: Anyone know much about ceramic coating headers? [Re: drew72] #1395593
03/01/13 05:56 PM
03/01/13 05:56 PM
Yes you are right but I was repeating what i was told by the onwers of the company who did the coating process verbadum.
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395594
03/02/13 01:17 PM
03/02/13 01:17 PM
Detroit, MI
CCPcoatings.com Offline
Detroit, MI
If you post some pics I can likely tell you what’s going on for sure. Is both the black and silver crumbling??? Based on your guys initial description it sounds like he’s a bit mixed up. As someone already pointed out, damage to that area of the primary is from a lean condition, NOT a rich one. I’m not sure what kind of Frankenstein process he’s doing, as most “non bright “ ceramics should be good for close to 2000F and it’s nearly impossible to hurt them. That being said, most failures for “Bright Ceramics” are caused from either a “too rich” or “too lean” condition. Both are equally BAD…. Too lean will cause failures between the head and mid primary. Too rich is from mid primary to the collector.
It appears that your coater never gave you any direction as many don’t, but special care is required for ALL bright ceramics. Most important on that list is that you NEVER break in, tune, or dyno an engine with bright ceramic headers. Doing so will put them in the dangerous rich / lean area discussed earlier as you can see below....
Re: Anyone know much about ceramic coating headers? [Re: Publicbottle] #1395595
03/02/13 01:22 PM
03/02/13 01:22 PM
Detroit, MI
Detroit, MI
You can damage bright headers in less than a minute if fuel or timing are off far enough.....
Re: Anyone know much about ceramic coating headers? [Re: CCPcoatings.com] #1395596
03/02/13 01:48 PM
03/02/13 01:48 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I was going to mention timing.
Break in an engine and see what happens when you have 20-25* of timing at 2500rpm vs 35*. Big difference in exhaust temps and that's on a well tuned engine from the carb side of your equation.
Re: Anyone know much about ceramic coating headers? [Re: RobX4406] #1395597
03/02/13 02:07 PM
03/02/13 02:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
while tuning an engine, yes, you can damage coatings, but remember, this is Stu's numbers matching original motor that's been in the car since the day it left the factory, and has already been previously tuned, by what sounds like, a wideband O2 sensor, so there's pretty much zero chance that his tune caused the coating to fail, unless he changed something else in/on the engine while the headers were off.
I'd be taking the headers TO the guy to show him how they failed--If all this was done over the phone, then he doesn't know what the failure looks like, but does know that off tune ups will damage the coating. If he continues to sing the same song about it being your fault because your tune is off, after he sees the headers in person, then cancel payment on your card, usually you have at least 90 days to do this, sometimes more if you get persuasive with the card company. If you paid by check/cash, then let him know you'll be letting everyone in the mid-pen area know how poor his quality of work is, and how lousy his customer service is after the fact.
**Photobucket sucks**
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395598
03/02/13 04:01 PM
03/02/13 04:01 PM
maryland
74yellowduster Offline
maryland
i would just do them yourself and do them right
http://www.eastwood.com/underhood-engine/exhaust-paints.html
you probably will not get your money back from the baddies even if you sue them.
use the eastwood header paint it lasts like 10 years for many people.
somewhere on their site they have a howto for restoring exhaust manifolds, some of the info there as to what products you can use could be adapted to doing your header project if they are rusty and rough
Re: Anyone know much about ceramic coating headers? [Re: 74yellowduster] #1395599
03/02/13 05:02 PM
03/02/13 05:02 PM
70sixpkrt Offline
70sixpkrt  Offline
I had mine ceramic coated at a place in Belmont. I forgot the name but they cost me $240. If you want I can try to find they name and give them a call for you. 7 years later they still look great.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Anyone know much about ceramic coating headers? [Re: 70sixpkrt] #1395600
03/02/13 05:04 PM
03/02/13 05:04 PM
70sixpkrt Offline
70sixpkrt  Offline
Pic
4-speed
3:54 Dana
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395601
03/02/13 06:59 PM
03/02/13 06:59 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
The coating is junk i got a set of hooker coated headers to prove it it even sent them back had them redone they got less then 50 miles on them no coating left
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Anyone know much about ceramic coating headers? [Re: MidPenMopar] #1395602
03/02/13 08:00 PM
03/02/13 08:00 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
they still rust........ warranty void if carb out of tune.. unless its a show car, i think its a waste
