CalTrac for 67 R/T #1392771
02/24/13 01:47 PM
02/24/13 01:47 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
My R/t is sagging in the rear...old girl is now over 45 and I was interested in a caltrac system,springs,traction bars,shocks. The car has frame extenders and I feel with the caltrac, I will get excellent traction/launch and can raise the rearend a bit for a better look.
Has anyone installed this?
Is it totally bolt in or some brackets welded/moved ?
Satisfaction rating ?
Thanks in advance to all
Re: CalTrac for 67 R/T [Re: terzmo] #1392772
02/24/13 02:42 PM
02/24/13 02:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cal tracs, mono springs and shocks all bolt right in if your not moving springs inboard!
Don't go with to stiff a mono spring.
You may want to replace the spring perches on your axle and at the very least box in the end of the present spring perches for more strength.
Re: CalTrac for 67 R/T [Re: terzmo] #1392773
02/24/13 02:43 PM
02/24/13 02:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What do you mean by frame extenders??
Re: CalTrac for 67 R/T [Re: Dodgem] #1392774
02/24/13 03:27 PM
02/24/13 03:27 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
frame extenders...connection between front and rear frame
Re: CalTrac for 67 R/T [Re: terzmo] #1392775
02/24/13 06:30 PM
02/24/13 06:30 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I installed the full Calvert system in my '67 last year. bolts right in in a couple of hours, tops. Pretty easy stuff, and a great upgrade. I picked up a full tenth in my 60' and 3 tenths in 1320 over my previous setup (stock springs with a set of South Side lift bars. If I had it to do over, I'd have gone with the +1" springs. The stock ht. springs are indeed stock ht, which is a little low on these cars.
Re: CalTrac for 67 R/T [Re: StealthWedge67] #1392776
02/24/13 10:50 PM
02/24/13 10:50 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I agree about the height..I was going with the 1+ and thanks...I did figure the suspension upgrade would improve the times on a slightly better than stock motor and figuring alternatives,I believe the cost is worth it. When I go to the big motor I won't have to worry about the suspension
any source recommendations ? nice car
Re: CalTrac for 67 R/T [Re: terzmo] #1392777
02/25/13 12:22 AM
02/25/13 12:22 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Buy direct from Calvert Racing. Sometimes John himself even answers the phone. I ask for Travis otherwise.
Re: CalTrac for 67 R/T [Re: Blues_Cuda] #1392778
02/25/13 01:31 PM
02/25/13 01:31 PM
Puyallup, WA
Puyallup, WA
Yep. Just call Calvert Racing and tell them what you've got and what you want. They'll be there with all the support you could need!
What I really like, is that in a few minutes I can dial the car for racing. Or, If I know I'm not going to be at the track for a while, I can soften the ride considerably for more comfortable street use. Quality of the Calvert stuff is top notch. Dont even think twice.
Re: CalTrac for 67 R/T [Re: StealthWedge67] #1392779
02/25/13 02:37 PM
02/25/13 02:37 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
We put the whole Caltracs setup on my '67 Coronet. You definately want 1" over stock heigth springs. Car sits nice. Now if I can quite getting hurt we might gwet it to the track one day.
Re: CalTrac for 67 R/T [Re: aquamist60] #1392780
02/25/13 05:31 PM
02/25/13 05:31 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have stock springs on mine with Caltracs and right now I like the stance. Hopefully it don't lower any more with a full tank of gas though. Springs are dead straight with no arch.
