How to identify what this 4sp is????? #1390797
02/20/13 11:37 AM
02/20/13 11:37 AM
IN
Dartman928 Offline OP
IN
Can someone help me to find out where I need to look on this 4sp to know what year it is and what it came out of?
Also this bell housing 2468372
Thank you
Re: How to identify what this 4sp is????? [Re: Dartman928] #1390798
02/20/13 11:42 AM
02/20/13 11:42 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Give me the casting number on the tailshaft extension housing, and I should be able to ID it for you. Bellhousing is 1965-69 big block, uses 130 tooth flywheel.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: How to identify what this 4sp is????? [Re: 64dodge572] #1390799
02/20/13 12:00 PM
02/20/13 12:00 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The bellhousing is also the one used on 67-69 383 Darts and Barracudas!
JB Rhinehart, Realist
A-Body's RULE!
Re: How to identify what this 4sp is????? [Re: Rhinodart] #1390800
02/20/13 03:23 PM
02/20/13 03:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a 4 speed that came from a I believe 69 RR.Guy pulled it and it sat in my buddys shop for probally 25 years.I often wonder if the car is still around and in the area.Ill have to get nos and post them.Wayne my bell I bought for my 65 was a 143 from a 69 GTX.I also should have the OE one from my 65 BB car.Rocky
Chrysler Firepower
Re: How to identify what this 4sp is????? [Re: Dartman928] #1390801
02/20/13 04:39 PM
02/20/13 04:39 PM
IN
IN
A number I see on the housing is 095884???
Re: How to identify what this 4sp is????? [Re: Dartman928] #1390802
02/20/13 06:02 PM
02/20/13 06:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Does the tailhousing have one mount or 2 ? if one is it right behind the maincase ... B body , or behind the trans mount pad , A body ?
On the pass side of the trans there will be a flat machined pad with numbers , what's stamped on it ?
Re: How to identify what this 4sp is????? [Re: JohnRR] #1390803
02/20/13 06:25 PM
02/20/13 06:25 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Or the one with both is E-body and 71-4 b-body....
Re: How to identify what this 4sp is????? [Re: QuickBpBp] #1390804
02/20/13 11:02 PM
02/20/13 11:02 PM
IN
IN
Its has one mount. I will have to work on getting some pics this weekend.
Thank you
Re: How to identify what this 4sp is????? [Re: Dartman928] #1390805
02/21/13 03:47 AM
02/21/13 03:47 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
