Give me the casting number on the tailshaft extension housing, and I should be able to ID it for you. Bellhousing is 1965-69 big block, uses 130 tooth flywheel.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
