Does the tailhousing have one mount or 2 ? if one is it right behind the maincase ... B body , or behind the trans mount pad , A body ?
On the pass side of the trans there will be a flat machined pad with numbers , what's stamped on it ?
Or the one with both is E-body and 71-4 b-body....
