Re: How to identify what this 4sp is?????
[Re: Dartman928]
#1390798
02/20/13 11:42 AM
02/20/13 11:42 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Give me the casting number on the tailshaft extension housing, and I should be able to ID it for you. Bellhousing is 1965-69 big block, uses 130 tooth flywheel.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Rhinodart]
#1390800
02/20/13 03:23 PM
02/20/13 03:23 PM
Posts: 21,059 Niles , Ohio
therocks
Niles , Ohio
I have a 4 speed that came from a I believe 69 RR.Guy pulled it and it sat in my buddys shop for probally 25 years.I often wonder if the car is still around and in the area.Ill have to get nos and post them.Wayne my bell I bought for my 65 was a 143 from a 69 GTX.I also should have the OE one from my 65 BB car.Rocky
Chrysler Firepower
[Re: JohnRR]
#1390803
02/20/13 06:25 PM
02/20/13 06:25 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
Does the tailhousing have one mount or 2 ? if one is it right behind the maincase ... B body , or behind the trans mount pad , A body ?
On the pass side of the trans there will be a flat machined pad with numbers , what's stamped on it ?
Or the one with both is E-body and 71-4 b-body....
