70 E body oil pan replacement #1390385
02/19/13 01:55 PM
02/19/13 01:55 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
Can I replace the oil pan while its in the car? My oil pan is dented up and I'm going to replace it, just wondering any tips or tricks about replacing it in car if it can be done. Thanks
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 70 E body oil pan replacement [Re: R_Blaha] #1390386
02/19/13 02:36 PM
02/19/13 02:36 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I've replaced my pan in my '71 Challenger and it's a deep race pan on a big block.
I had to drop the center link on the steering and I think I took out the motor mount bolts and raised the engine off the pads about 1 1/2". Just sat the mounts on some wooden blocks.
If your's is a small block, I wouldn't see any other obstacles.
Re: 70 E body oil pan replacement [Re: R_Blaha] #1390387
02/19/13 03:28 PM
02/19/13 03:28 PM
No problems at all if it is a stock pan, drop the center link as already suggested You will probally need a 1/2 inch box end wrench to remove the front four bolts BTW, is it a BB or SB motor
Re: 70 E body oil pan replacement [Re: Cab_Burge] #1390388
02/19/13 04:52 PM
02/19/13 04:52 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
Thanks, it's a 340. I figured I would ask before tackling it
1989 Mustang GT
1993 mustang lx 5.0
2013 CVO Roadglide
Re: 70 E body oil pan replacement [Re: R_Blaha] #1390389
02/19/13 11:11 PM
02/19/13 11:11 PM
SB are a little harder Doable, but not as easy as the BB wth the flat oil pan rails
