Re: 8 lug converter modifition
[Re: dafixr]
#1386155
02/12/13 03:45 PM
02/12/13 03:45 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I haven't used a 727 in years but is there any reason why studs are not to use studs and lock nuts on use lock wire???
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1386157
02/12/13 03:51 PM
02/12/13 03:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The clearance between the bolt head and block... even with bolts the head thickness is pretty thin for clearance... the welds on that conv look like they didnt penetrate at all(like the weld was sitting on the top of the metal... it could be the heat affected zone I'm looking at
[Re: Evil Spirit]
#1386162
02/13/13 01:24 PM
02/13/13 01:24 PM
Posts: 168 Washington State, USA
Winchester 73
Wait till the bad weld police get ahold of this. After 5 years of bashing suspension parts, they were LONG overdue for a new target.
i vil be informing ze veld police of zis immidiately
[Re: prochargedhemi]
#1386166
02/14/13 12:57 PM
02/14/13 12:57 PM
MR_P_BODY
those lugs sure look tig welded to me
I think they are tigged also... looks to be under cut with no penetration... at least his conv shop is taking care of him... thats good
[Re: 727specialist]
#1386169
02/15/13 02:49 PM
02/15/13 02:49 PM
Posts: 279 Chicago land, IL
dafixr
Chicago land, IL
Keith, I was going to send you the pictures, glad you logged in.
We will have to get the trans over to you, so you can see how your modification to the trans are working after 90 + passes hitting it with 500 NOS.
And also so you can check out the 1.95 first set that we had made up.
Engine is at LEGEND getting freshened up, had 1 bad valve and the new liners we had put in the bores 2 years ago were knocked around little, having over size pistons made up at Diamond
Ordered new rear rims going to a bigger tire so we may have to keep a eye on the high gear clutches.
JIM
