8 lug converter modifition #1386154
02/12/13 03:32 PM
02/12/13 03:32 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Pic's of our newly modified converter w 8 lugs and 8 lug flex plate
We were tearing the lugs off the converter with our 7.60 passes.
Re: 8 lug converter modifition [Re: dafixr] #1386155
02/12/13 03:45 PM
02/12/13 03:45 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I haven't used a 727 in years but is there any reason why studs are not to use studs and lock nuts on use lock wire???
home of the
Sox and Martin Hemi Duster
Re: 8 lug converter modifition [Re: dafixr] #1386156
02/12/13 03:46 PM
02/12/13 03:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow looks killer!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 8 lug converter modifition [Re: HEMIFRED] #1386157
02/12/13 03:51 PM
02/12/13 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The clearance between the bolt head and block... even
with bolts the head thickness is pretty thin for clearance...
the welds on that conv look like they didnt penetrate
at all(like the weld was sitting on the top of the
metal... it could be the heat affected zone I'm
looking at
Re: 8 lug converter modifition [Re: MR_P_BODY] #1386158
02/13/13 02:10 AM
02/13/13 02:10 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Can you post better pictures of where the weld broke? I'm also not seeing any evidence of penetration.
Re: 8 lug converter modifition [Re: Kevins493] #1386159
02/13/13 10:15 AM
02/13/13 10:15 AM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
These were the only pictures we took before sending converter back. They changed the back plate and added the extra lugs no charge.
Re: 8 lug converter modifition [Re: dafixr] #1386160
02/13/13 11:51 AM
02/13/13 11:51 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
as others stated, there isn't any weld penetration on the ring gear. poor weld job.
Re: 8 lug converter modifition [Re: dafixr] #1386161
02/13/13 01:15 PM
02/13/13 01:15 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Wait till the bad weld police get ahold of this. After 5 years of bashing suspension parts, they were LONG overdue for a new target.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 8 lug converter modifition [Re: Evil Spirit] #1386162
02/13/13 01:24 PM
02/13/13 01:24 PM
Washington State, USA
W
Winchester 73 Offline
W
i vil be informing ze veld police of zis immidiately
Re: 8 lug converter modifition [Re: Winchester 73] #1386163
02/13/13 02:00 PM
02/13/13 02:00 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Their is not enough weld on the bosses, I would find a reputable weld shop in your area and have them reweld it with more heat and a larger fillet and take your flexplate to use as a fixture for proper location
Re: 8 lug converter modifition [Re: formula S] #1386164
02/14/13 12:40 PM
02/14/13 12:40 PM
dogdays Offline
dogdays  Offline
AMEN.
This is why I hate MIG welders in the hands of the uninformed. It's so easy to make a really pretty weld that doesn't do anything.
Years ago my cousin needed some college money so he took a job at a farm equipment manufacturer named Haybuster. He was raving about how easy it was to weld with a MIG. Beautiful weld every time. The kicker - training was like 5 minutes!
Just think, from zero to pro welder in 5 minutes.
Give me a stick anytime.
R.
Re: 8 lug converter modifition [Re: dogdays] #1386165
02/14/13 12:53 PM
02/14/13 12:53 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
those lugs sure look tig welded to me
Re: 8 lug converter modifition [Re: prochargedhemi] #1386166
02/14/13 12:57 PM
02/14/13 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think they are tigged also... looks to be under cut
with no penetration... at least his conv shop is taking
care of him... thats good
Re: 8 lug converter modifition [Re: MR_P_BODY] #1386167
02/14/13 06:22 PM
02/14/13 06:22 PM
dogdays Offline
dogdays  Offline
Yeah, yer right, not MIG welds. I guess I was waiting to go off on something today. But, no penetration regardless of what welds.
R.
Re: 8 lug converter modifition [Re: dafixr] #1386168
02/15/13 01:38 PM
02/15/13 01:38 PM
NW Indiana USA
727specialist Online content
727specialist  Online Content
NW Indiana USA
Looks good
Shouldn't have any more problems with that. Keith
Re: 8 lug converter modifition [Re: 727specialist] #1386169
02/15/13 02:49 PM
02/15/13 02:49 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Keith,
I was going to send you the pictures, glad you logged in.
We will have to get the trans over to you, so you can see how your modification to the trans are working after 90 + passes hitting it with 500 NOS.
And also so you can check out the 1.95 first set that we had made up.
Engine is at LEGEND getting freshened up, had 1 bad valve and the new liners we had put in the bores 2 years ago were knocked around little, having over size pistons made up at Diamond
Ordered new rear rims going to a bigger tire so we may have to keep a eye on the high gear clutches.
JIM
Re: 8 lug converter modifition [Re: dafixr] #1386170
02/15/13 03:25 PM
02/15/13 03:25 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho the proper solution would have been to actually weld the four lugs as opposed to merely sticking them on. i hope the person that welded that converter got the chance to see it so they know it wasn't done anywhere near correct.
did transmission specialties do the first converter that failed?
