Re: Triple Black Bee
[Re: OhioMopar]
#1376054
08/12/13 08:16 PM
08/12/13 08:16 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
The Nats are over. You are home. Your Summit credit has probably cleared. What did you get done today?? ![](/ubbthreads/images/graemlins/biggrin.gif)
Old, tired, and sometimes broke down. Me, not my car...
[Re: Shoozy]
#1376055
08/12/13 09:26 PM
08/12/13 09:26 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Credit hit on Thursday. All I did today was buy the pipe plug to fix my oil leak. Looks like my next day of wrenching will be Wednesday. I will get the intake sealed and tighten the fuel line and get it running so I can make it run aand start tuning it to idle.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: basketcase]
#1376057
08/17/13 03:54 PM
08/17/13 03:54 PM
OhioMopar
Mt.Gilead, Ohio
No pics, but I pulled the intake and got the oil galley plugged. Ran into another issue on the other side. The oil pressure sending unit is too fat to fit between the galley and the block. So I either need to raise it somehow, a lot, or find a smaller sending unit.
[Re: OhioMopar]
#1376058
08/19/13 12:58 PM
08/19/13 12:58 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Unusual to hafta' look for a smaller unit...
[Re: OhioMopar]
#1376060
08/19/13 05:33 PM
08/19/13 05:33 PM
OhioMopar
Mt.Gilead, Ohio
Did a tiny bit of online research. I think I got the wrong oil pressure switch. I looked at a couple pics and the application for my car should have a longer 1/8" fitting on it. The one I got had a short 1/4", or maybe a little larger, fitting. Simple enough.
[Re: Shoozy]
#1376062
08/25/13 08:01 PM
08/25/13 08:01 PM
Posts: 1,567 Ky
jt4406
Ky
Darin Here's a pic of the one I got for my 70 challenger, don't really know where I got it though. Very likely just a parts store piece. (if you open the "attachment" it may be easier to see). Jess
Yeah, it's hopped up to over 160...
[Re: OhioMopar]
#1376065
09/01/13 08:15 PM
09/01/13 08:15 PM
OhioMopar
Mt.Gilead, Ohio
Back at it today. I got the new valley pan gasket on it and put the correct oil pressure sending unit on it. Got the intake back on and tomorrow I will finish buttoning the rest of the stuff up and fire it up again.
[Re: OhioMopar]
#1376066
09/01/13 08:19 PM
09/01/13 08:19 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: RSNOMO]
#1376067
09/01/13 10:17 PM
09/01/13 10:17 PM
OhioMopar
Mt.Gilead, Ohio
Gotta friggin' work. I have little doubt it will be roadworthy by then. But the best I can do is drive it to work Norwalk weekend.
[Re: MuuMuu101]
#1376069
09/03/13 09:42 PM
09/03/13 09:42 PM
OhioMopar
Mt.Gilead, Ohio
I bought the stuff I need to keep plugging away. My phone died before I could snap a picture of it, but the intake is back on, the carb is back on, fuel line connected, vacuum lines hooked up, and I'm gonna be back on it before the weekend. I still have to fight with a drivers side motor mount, but I ripped the first one, so I'm avoiding it for now. I still need to fill/adjust the trans. More of a fine tuning, but needs done. Heater hoses and anti-freeze and it's time to start tuning the idle and advance curve. Exhaust and a rear tire change and hopefully some road miles on it starting in the next couple weeks. ![](/ubbthreads/images/graemlins/luck.gif) ![](http://i160.photobucket.com/albums/t181/OhioMopar/Triple%20black%20Bee/20130901_153207_zps963ab5eb.jpg)
[Re: OhioMopar]
#1376070
09/06/13 08:30 AM
09/06/13 08:30 AM
OhioMopar
Mt.Gilead, Ohio
ITS ALIVE!! Crappy cell phone video, but it's all I had at the time. <a href=http://s160.photobucket.com/albums/t181/OhioMopar/Triple%20black%20Bee/?action=view¤t=20130905_193409_zpsc1e28a9e.mp4 target=_blank><img src=http://static.photobucket.com/player.swf?file=http://vid160.photobucket.com/albums/t181/OhioMopar/Triple%20black%20Bee/20130905_193409_zpsc1e28a9e.mp4 border=0 alt=></a> It has an oil leak, and the carb is leaking from the dual feed line. But it idles and sounds wonderful. I'll add some water tonight and see if the heater core leaks. If it does I'll bypass it for now. I need to borrow a timing light so I can set the advance once I fix those pesky stout springs in the distributor. It sounds healthy and holds some really good oil pressure! ![](/ubbthreads/images/graemlins/boogie.gif) I have some more pressing matters that require my monetary attention, but I'll keep on fixing the little things and looking at a bit of road time next week or the week after. Trans goes through all the gears(except reverse. Still need to figure it out. Probably have the lever flipped.) I'm pretty pleased! Very happy with my engine purchase from David Eschedor, and also some guidance in what it likes tuning wise from its previous caretaker, Doug Markel. Couple of great Mopar guys. ![](/ubbthreads/images/graemlins/bow.gif) I still have some things to fix before it hits the road, but the list keeps shrinking! 2nd More to come.
[Re: OhioMopar]
#1376071
09/06/13 08:41 AM
09/06/13 08:41 AM
OhioMopar
Mt.Gilead, Ohio
Okay, if someone smarter than me can get the video to load, feel free!
