Page 3 of 3 1 2 3
Re: Pocket Porting Pics Please [Re: pittsburghracer] #1372191
01/20/13 05:52 PM
01/20/13 05:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pocket Porting Pics Please [Re: pittsburghracer] #1372192
01/20/13 05:58 PM
01/20/13 05:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At least now he has a idea of what they should look
like instead of guessing at it.... thanks guys for
posting some pics... I'm SURE it'll help him....
we gotta help out the kids...... same as when we were
young and learning
Re: Pocket Porting Pics Please [Re: pittsburghracer] #1372193
01/20/13 06:03 PM
01/20/13 06:03 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Re: Pocket Porting Pics Please [Re: Hot 340] #1372194
01/20/13 06:04 PM
01/20/13 06:04 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
2
Re: Pocket Porting Pics Please [Re: Hot 340] #1372195
01/20/13 06:04 PM
01/20/13 06:04 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
3
Re: Pocket Porting Pics Please [Re: Hot 340] #1372196
01/20/13 08:23 PM
01/20/13 08:23 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
My Econo W2's.I mainly just removed the casting marks and lines.I also worked on the "short turn" sum ,widdled down the pushrod pinch and gasket matched them .BTW , i used a regular Dewalt drill even though i have a die grinder.I just prefer to use it with diamond carbide bits ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Pocket Porting Pics Please [Re: The Shocker] #1372197
01/20/13 08:24 PM
01/20/13 08:24 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Another pic ...
Re: Pocket Porting Pics Please [Re: Sb Valiant] #1372198
01/20/13 09:36 PM
01/20/13 09:36 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Air wants to go around as large a radius as possible.A huge bowl opened up to a vertical(90deg) angle right up to the seat diameter doesn't help flow as much as the increase in area would lead you to believe. Keep the throat diameter at 85-88% of the seat.Give the air a gradual turn to go around.This is the reason for all of the multiple angles on valve jobs, to create a radius from bowl to seat.
Re: Pocket Porting Pics Please [Re: 67_Satellite] #1372199
01/20/13 09:41 PM
01/20/13 09:41 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Why don't you give Brett Miller (W5Dart66) a call and see what he can do for you. He'll be able to set your heads up for you and do what port/ machine work you want to do. PM me if you want his number. -Andy
Re: Pocket Porting Pics Please [Re: 340_Dart] #1372200
01/21/13 12:17 AM
01/21/13 12:17 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Page 3 of 3 1 2 3
