Re: Pocket Porting Pics Please
[Re: Sb Valiant]
#1372152
01/19/13 12:28 PM
01/19/13 12:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
LOL... your never gonna do it with steel wool... your gonna need a die grinder... I have both electric and air... I dont think I have any pics of my econo W-2s but I'll look
[Re: Sb Valiant]
#1372155
01/19/13 02:37 PM
01/19/13 02:37 PM
MR_P_BODY
LOL thanks Mr P Body I have a little electric die grinder!
I dont mean a Dremel... I have a Dewalt DW660 with a variable speed adjuster(that unit is a 1/4" shank)... plus you need burrs to cut with... I have about 20 but I tend to use about 4 the most.... as said... practice on a JUNK head
[Re: MR_P_BODY]
#1372156
01/19/13 05:23 PM
01/19/13 05:23 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
I'd like to see some pics as well. I plan on getting the porting template kit and doing some big block heads. I agree your going to be there forever with a dremel. I have a nice craftsman electric die grinder(1hp if memory serves me). I'll post a picture of it when I get a chance.
[Re: MPerry]
#1372157
01/19/13 05:46 PM
01/19/13 05:46 PM
MR_P_BODY
I looked through all my pics... I dont have any of port work... I guess I forget to take pics(if it wasnt for my wife I dont know if I would have many pics)
[Re: MR_P_BODY]
#1372158
01/19/13 07:43 PM
01/19/13 07:43 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
you need on of these
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1372159
01/19/13 08:11 PM
01/19/13 08:11 PM
MR_P_BODY
Yeah I could use a assistant like that in the shop... two things would happen... 1... I wouldnt get any work done.. 2.... I'd be divorced ... LOL
[Re: MR_P_BODY]
#1372160
01/19/13 08:57 PM
01/19/13 08:57 PM
Posts: 6,149 Melbourne , Australia
LA360
You will need a grinder with a 1/4" shank, a Dremel with a 1/8" shank isn't going to do squat. Do your port work before you have the valve job finished. One of the most important thing for a beginner is being able to control the grinder and burr. I have sold heads to a few guys now that tried porting their heads themselves and made a complete mess. It's very easy to ruin a perfectly good head if you're not careful. As everyone has said, try on a junk W2 before you start. Pictures only show so much, they don't give a true insight into the actual shape
Alan Jones
[Re: sixpackgut]
#1372161
01/19/13 11:08 PM
01/19/13 11:08 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I have one of those ...she doesn't work in the garage with me anymore. 5 Kids has really cut down on how often she can clean my garage too...
[Re: Quicksilver440]
#1372162
01/19/13 11:20 PM
01/19/13 11:20 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I started with a dremell, I think it was a good idea for a beginner as you don't remove material as fast (too fast if your not careful). Now I mostly use carbide bits in my 1/4 inch air grinder. It has a max speed adjuster as well as variable speed depending on how hard you squeeze it. I do still use a Dremmel for polishing the ex port.
#1372165
01/19/13 11:58 PM
01/19/13 11:58 PM
MR_P_BODY
If you are going to run an air grinder...make sure you have a good compressor.
I have a BIG compressor but I prefer the electric die grinder.. its a bit heavier but eats less power and the compressor is noisy when it fires up
[Re: pittsburghracer]
#1372168
01/20/13 11:20 AM
01/20/13 11:20 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
When I used the porting template kit, I used a "thimble sized" carbide cutter to make a cut for each template as it should be clocked. Thimble sized, meaning it's about the size of your pinky and shaped about the same. Another cutter a little smaller gets down between the guide and port wall to run that trough. After the templates are sunk, I break out the biggest/roundest stone that will fit into the bowl. The law of averages, as I say, will take out metal from the bowl as you keep moving it around to get down to where the template cuts were made. Some blending of the bowl to the port entry (I just roll the short turn and minimize material removal) and an intake gasket match/blend later......... Probably not the best approach but it gained me 3 mph through the traps and had more low end grunt too!
[Re: Dean_Kuzluzski]
#1372169
01/20/13 12:02 PM
01/20/13 12:02 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
A bigger and heavier electric diegrinder eats up a lot of the bad vibrations to.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
