Re: Nice stroker 383 on the dyno today [Re: Streetwize] #1371701
01/18/13 09:35 PM
01/18/13 09:35 PM
SoCal
Brian Hafliger Offline OP
SoCal
Awesome job, Brian!
How do the PRW's compare to the Comps? Are they an exact copy?
Love to see a side by side with a 440-2D on that....484 is it?
It's a 496 cid (4.31x4.25).
The PRW is bushed, and available in 1.6 ratio and are stainless, not chromoly. I like them alot!
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371702
01/18/13 10:26 PM
01/18/13 10:26 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Brian do you feel the smaller bore of the 383 hurts performance significantly over lets say a 400 or 440 block, if all things were the same ( stroke, heads,intake, cam specs) the only differnce being the larger bore of the b440 and 400?. I have always wonderd why more people don't build Stroker 383"s. Could you tel us why people seem to forget about the 383 when it comes to building big inch strokers and racing engines. What are the downfalls of it? thanks in advance. If I don't go Stroker smallblock ive always thought about building a big inch 383 but most people I talk to say forget it and go straight to the 400 or 440. Thanks in advance good sir!
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371703
01/18/13 10:27 PM
01/18/13 10:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
Time to paint the intake manifold the same color as the motor, put the coil on the intake and put some stock looking breather caps on it Did you decide to put the wide LSA on the cam for the idle vacume due to the power brakes? Just wondering What is the elevation of your dyno shop? Isn't it right around 20 ft. below sea level?
Re: Nice stroker 383 on the dyno today [Re: Abodyjohn88] #1371704
01/18/13 11:11 PM
01/18/13 11:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i'm not brian, but the 400,has thicker main bearing webbing,& the smaller bore of the 383 shrouds the valves more than 400,440
Re: Nice stroker 383 on the dyno today [Re: Abodyjohn88] #1371705
01/18/13 11:23 PM
01/18/13 11:23 PM
AndyF Offline
AndyF  Offline
At higher engine speeds the larger bore 400 will work better. But for a real street motor like this one the 383 block works just fine. In fact, the smaller bore size might help reduce detonation a tiny bit.
Re: Nice stroker 383 on the dyno today [Re: Abodyjohn88] #1371706
01/19/13 03:06 AM
01/19/13 03:06 AM
SoCal
SoCal
I tried talking this guy into a 400 block, but he insisted on using his 383! I prefer the larger bore, and I'm sure it's worth some power but I doubt on a build like this it's worth more than 20HP.
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Cab_Burge] #1371707
01/19/13 03:08 AM
01/19/13 03:08 AM
SoCal
SoCal
I use the wide lca for better vaccum and to spread power out better so there is some girth to the power band. I was held to a very tight budget on this build so my leash kept me from doing more
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: AndyF] #1371708
01/19/13 03:09 AM
01/19/13 03:09 AM
SoCal
SoCal
Yes I agree, smaller bore will curb detonation better than a larger bore. Still like the large bores though...
Brian Hafliger
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371709
01/19/13 11:10 AM
01/19/13 11:10 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
So, what did a build like this cost the customer?
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371710
01/19/13 11:14 AM
01/19/13 11:14 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
good little motor for the street.
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371711
01/19/13 04:31 PM
01/19/13 04:31 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I love the little 383's. You can pickup complete 383 cores for $50 all over. I just dropped off some stealth heads, .567 roller cam and 1.6 MP rockers for my new 383 to the engine builder this morning.
Mine is very similar except I stayed with a stock stroke, 12 to 1 compression, M1 Single Plane and solid roller cam. The builder is estimating it will make over 500-550 HP but I'm skeptical.
We'll see soon enough.
Congrats on another successful build.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Nice stroker 383 on the dyno today [Re: 69dart] #1371712
01/20/13 12:28 PM
01/20/13 12:28 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Excellent work on that engine build. Sounds awesome!!
Re: Nice stroker 383 on the dyno today [Re: 69Cuda340S] #1371713
01/20/13 03:07 PM
01/20/13 03:07 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That's cool! Being someone that needs a low deck engine for his Bee, a build similar to this seems very tempting. Don't know if I would stick with a 383. But I would like to.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Nice stroker 383 on the dyno today [Re: Brian Hafliger] #1371714
01/20/13 05:12 PM
01/20/13 05:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thank you for sharing. Intersting.
Re: Nice stroker 383 on the dyno today [Re: BSB67] #1371715
01/21/13 02:33 AM
01/21/13 02:33 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I will be in touch for a set of hydraulic roller lifters for our 511 in the future. I like these sleeper builds.
Re: Nice stroker 383 on the dyno today [Re: 69dart] #1371716
01/21/13 11:25 PM
01/21/13 11:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
With some good headwork I would say over 500 and without just under.
