Page 1 of 3 1 2 3
1971 Vapor Retun Line #1363644
01/03/13 12:08 PM
01/03/13 12:08 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
I got a complete gas line kit from Right Stuff Detailing for a 1971 Hemi Cuda. Has the supply line plus the two vapor lines. Everything is hooked up and fits good except for the hard vapor line the runs up along the passenger inner fender.
From the pictures I have seen it looks like this line should run up about even with the top of the shock bolt. The line they supplied stops about 4" behind the shock bolt. Any idea what is correct? If it is wrong what is a good source for the correct one.
Also what is the clamp that is suppose to hold the line on to the fender? Any dimensions of where that clamp gets screwed on would be great also.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363645
01/03/13 04:05 PM
01/03/13 04:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The vapor line is a 2 peice deal. The suppy and vapor get's clamped and screwed to the car. The hemi return line get's fasten to the other lines with small S clamps.
Re: 1971 Vapor Retun Line [Re: Challenger 1] #1363646
01/03/13 04:29 PM
01/03/13 04:29 PM
Wisconsin
Wisconsin
See in this picture you posted how the end of the tube comes out directly above the top of the shock mount. Mine is way short of coming to that point.
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363647
01/03/13 04:43 PM
01/03/13 04:43 PM
Crook County, ILL
Mastershake340 Online content
Mastershake340  Online Content
Crook County, ILL
I remember we ran into some confusion when we were installing a new fuel tank and lines on my '71 V code Challenger a while back. We had began to install one line incorrectly and the vapor return line didn't seem to be ending up where we expected it, until we figured out the short piece went up from the frame along the inner fender and attached to a longer section coming from the fuel tank with a piece of rubber fuel line (the fact that we were installing the lines at about 3 in the morning might have had something to do with it!)
I forget which of the companies I bought my set from, but they assured me it included all the clamps and clips I needed. What I found was missing from their line kit was the clip and bolt that installs in that indentation on the inner fender. If your car has the correct inner fender it should have the indentation with a hole for the bolt, where the clip goes. I searched around but didn't find anyone selling a reproduction of that clip and bolt. I ended up buying a used one from a Moparts member, cleaned it up and used it. I'm at work so I don't have my pictures showing that clip and bolt here to post right now.
Re: 1971 Vapor Retun Line [Re: Mastershake340] #1363648
01/03/13 04:48 PM
01/03/13 04:48 PM
Wisconsin
Wisconsin
I forget which of the companies I bought my set from, but they assured me it included all the clamps and clips I needed. What I found was missing from their line kit was the clip and bolt that goes in that indentation on the inner fender. I searched around but didn't find anyone selling a reproduction of that. I ended up buying a used one from a Moparts member, cleaned it up and used it. I'm at work so I don't have my pictures showing that clip and bolt here to post right now.
Pictures of that clip and bolt would be great. Is their only one at the top or is their one at the bottom also.
That short piece of line that goes from the frame up the fender is the one I am talking about. Mine seems to be way to short. It follows the fender and around the frame fine but doesn't come forward as far as it should. I will try and get a picture of it tomarrow.
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363649
01/03/13 04:56 PM
01/03/13 04:56 PM
Crook County, ILL
Crook County, ILL
If no one else posts one first, I'll post a picture of mine this evening. I circled the area on Gary's picture where the clip and bolt I'm referring to are installed. There is another clipping tab for the line on the top of the frame and another on the firewall below the heater motor IIRC, but those are welded on the car body and not included in any of the fuel line kits.
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363650
01/03/13 05:21 PM
01/03/13 05:21 PM
Cincinnati, Ohio
Cincinnati, Ohio
I installed hemi gas lines on my 74 this past summer and reused the original clamps, this is what they look like. I still have my originals from my 71 car, just was to lazy to clean them up and reuse them, wish I did and may reinstall them some day. I bead blasted these clean and painted them with Eastwoods "Tank Tone". I like that stuff...
Re: 1971 Vapor Retun Line [Re: Mastershake340] #1363651
01/03/13 05:22 PM
01/03/13 05:22 PM
Wisconsin
Wisconsin
Yea I think my line is too short to even get to the circled area and put the clip on. Also looks like I am missing any tabs that would be on the frame or fire wall.
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363652
01/03/13 06:54 PM
01/03/13 06:54 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
Is the line supplied similar to this line?
Re: 1971 Vapor Retun Line [Re: JAK] #1363653
01/03/13 06:55 PM
01/03/13 06:55 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
another pic
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363654
01/03/13 07:13 PM
01/03/13 07:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
Did you read where we said it was a 2 peice line? at least on a challenger. Sounds like your missiing the short peice?
Re: 1971 Vapor Retun Line [Re: Challenger 1] #1363655
01/03/13 07:30 PM
01/03/13 07:30 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
This is the second line as directly under the firewall by the frame rail there is a flexible hose connection. This line also has the check valve in it where the flexible hose connects going to the breather cap.
I have seen this also on a 1972 Satellite parts car. My challenger has a build date of 6-71.
Re: 1971 Vapor Retun Line [Re: JAK] #1363656
01/03/13 08:01 PM
01/03/13 08:01 PM
Wisconsin
Wisconsin
I have a picture of an original car and I don't see where it is a two piece line. It is one piece from the frame rail to up by the shock tower.
Re: 1971 Vapor Retun Line [Re: JAK] #1363657
01/03/13 08:05 PM
01/03/13 08:05 PM
Wisconsin
Wisconsin
Nope it is not like that. The shape is all correct it is just not long enough it seems.
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363658
01/03/13 08:54 PM
01/03/13 08:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
You can't see it in that picture, it's down under right in front of the trans and tortion bar cross member. The red cap in this photo is where the connection is made. It's a 2 piece line.
Re: 1971 Vapor Retun Line [Re: Challenger 1] #1363659
01/03/13 09:04 PM
01/03/13 09:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Fuel lines were the very first item I installed on my car, it don't get any easier than right now. lol
Just finished pressure washing off all the buffing compound before assembly begins.
Re: 1971 Vapor Retun Line [Re: Challenger 1] #1363660
01/03/13 10:51 PM
01/03/13 10:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
could I see a picture of the s clip and bolt that holds the line on the fender
Re: 1971 Vapor Retun Line [Re: Mopar_Mudder] #1363661
01/03/13 11:15 PM
01/03/13 11:15 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
By the frame rail is where the splice is.
71B and E share the same lines. I have some originals.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 Vapor Retun Line [Re: moparmarks] #1363662
01/03/13 11:47 PM
01/03/13 11:47 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Not to hijack the thread but, what color is the car? ( code )what brand paint did you use ? looks really nice !
Re: 1971 Vapor Retun Line [Re: 71birdJ68] #1363663
01/04/13 12:06 AM
01/04/13 12:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
Not sure if the screw or clamp is original? I think the screw is because I put all the original screws back in after stripping and before painted the car.
If your asking about my car, it's GY8 It's PPG color and would have to look at the can for more info. Thanks
Page 1 of 3 1 2 3
