Re: 1971 Vapor Retun Line
[Re: Challenger 1]
#1363646
01/03/13 04:29 PM
01/03/13 04:29 PM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
The vapor line is a 2 peice deal. The suppy and vapor get's clamped and screwed to the car. The hemi return line get's fasten to the other lines with small S clamps.
See in this picture you posted how the end of the tube comes out directly above the top of the shock mount. Mine is way short of coming to that point.
[Re: Mastershake340]
#1363648
01/03/13 04:48 PM
01/03/13 04:48 PM
Mopar_Mudder
Wisconsin
I remember we ran into some confusion when we were installing a new fuel tank and lines on my '71 V code Challenger a while back. We had began to install one line incorrectly and the vapor return line didn't seem to be ending up where we expected it, until we figured out the short piece went up from the frame along the inner fender and attached to a longer section coming from the fuel tank with a piece of rubber fuel line (the fact that we were installing the lines at about 3 in the morning might have had something to do with it!) I forget which of the companies I bought my set from, but they assured me it included all the clamps and clips I needed. What I found was missing from their line kit was the clip and bolt that goes in that indentation on the inner fender. I searched around but didn't find anyone selling a reproduction of that. I ended up buying a used one from a Moparts member, cleaned it up and used it. I'm at work so I don't have my pictures showing that clip and bolt here to post right now.
Pictures of that clip and bolt would be great. Is their only one at the top or is their one at the bottom also.
That short piece of line that goes from the frame up the fender is the one I am talking about. Mine seems to be way to short. It follows the fender and around the frame fine but doesn't come forward as far as it should. I will try and get a picture of it tomarrow.
[Re: Mopar_Mudder]
#1363654
01/03/13 07:13 PM
01/03/13 07:13 PM
Challenger 1
Cincinnati, Ohio
Did you read where we said it was a 2 peice line? at least on a challenger. Sounds like your missiing the short peice?
[Re: JAK]
#1363656
01/03/13 08:01 PM
01/03/13 08:01 PM
Mopar_Mudder
Wisconsin
This is the second line as directly under the firewall by the frame rail there is a flexible hose connection. This line also has the check valve in it where the flexible hose connects going to the breather cap.
I have seen this also on a 1972 Satellite parts car. My challenger has a build date of 6-71.
I have a picture of an original car and I don't see where it is a two piece line. It is one piece from the frame rail to up by the shock tower.
[Re: JAK]
#1363657
01/03/13 08:05 PM
01/03/13 08:05 PM
Mopar_Mudder
Wisconsin
Is the line supplied similar to this line?
Nope it is not like that. The shape is all correct it is just not long enough it seems.
[Re: Mopar_Mudder]
#1363661
01/03/13 11:15 PM
01/03/13 11:15 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
By the frame rail is where the splice is. 71B and E share the same lines. I have some originals.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
