I got a complete gas line kit from Right Stuff Detailing for a 1971 Hemi Cuda. Has the supply line plus the two vapor lines. Everything is hooked up and fits good except for the hard vapor line the runs up along the passenger inner fender.
From the pictures I have seen it looks like this line should run up about even with the top of the shock bolt. The line they supplied stops about 4" behind the shock bolt. Any idea what is correct? If it is wrong what is a good source for the correct one.
Also what is the clamp that is suppose to hold the line on to the fender? Any dimensions of where that clamp gets screwed on would be great also.
