W9 headbolts
#1363601
01/03/13 11:15 AM
01/03/13 11:15 AM
Posts: 85 europe
WBR
europe
I'm in need for headbolts or studs for W9rp heads. Emailed ARP, got an answer: We do not have any for this configuration yet. What are you guys using?
Street driven, 421 Sb, NA, 9.98/137
Re: W9 headbolts
[Re: Ck[FIN]]
#1363604
01/03/13 12:14 PM
01/03/13 12:14 PM
Posts: 85 europe
WBR
europe
For aluminium blocks? Does it matter, i have a iron block? Is there anything cheaper available, Bolts, that would work?
Re: W9 headbolts
[Re: WBR]
#1363605
01/03/13 01:15 PM
01/03/13 01:15 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Todd at Marsh Performance has them I've bought them from him, and were are a little better priced. The differance in the studs for an aluminum block is the part that screws in the block is longer for more enguagement and have a bullet tip. You can cut some of the threads off and they will be fine. http://www.mopartsracing.com/
Re: W9 headbolts
[Re: tubtar]
#1363614
01/04/13 12:29 AM
01/04/13 12:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I got mine for a conventional W-9 from Ryan J and they were not cheap. Even compared to regular ARP stuff.......then I had to replace the eight point nuts with the smaller 12 point on the studs in between the valve springs. But I'm not complaining.........that was the cheap part of the deal.
Yeah I replace all of the nuts with 12 points... and people think is cheap to build a W-9
