W9 headbolts #1363601
01/03/13 11:15 AM
01/03/13 11:15 AM
europe
W
WBR Offline OP
WBR  Offline OP
W
europe
I'm in need for headbolts or studs for W9rp heads. Emailed ARP, got an answer: We do not have any for this configuration yet. What are you guys using?
Street driven, 421 Sb, NA, 9.98/137
Re: W9 headbolts [Re: WBR] #1363602
01/03/13 11:37 AM
01/03/13 11:37 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Mopar actually sells a kit. Google is ur friend
Re: W9 headbolts [Re: fishy340] #1363603
01/03/13 11:46 AM
01/03/13 11:46 AM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
-1965 Valiant 9.03s 358cu.in R5P7-
Re: W9 headbolts [Re: Ck[FIN]] #1363604
01/03/13 12:14 PM
01/03/13 12:14 PM
europe
W
WBR Offline OP
WBR  Offline OP
W
europe
For aluminium blocks? Does it matter, i have a iron block? Is there anything cheaper available, Bolts, that would work?
Re: W9 headbolts [Re: WBR] #1363605
01/03/13 01:15 PM
01/03/13 01:15 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Todd at Marsh Performance has them I've bought them from him, and were are a little better priced.
The differance in the studs for an aluminum block is the part that screws in the block is longer for more enguagement and have a bullet tip. You can cut some of the threads off and they will be fine.
http://www.mopartsracing.com/
Re: W9 headbolts [Re: SB412DUSTER] #1363606
01/03/13 01:37 PM
01/03/13 01:37 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Talk to BondoBob @ Bob's Pro Fab.
He got my heads complete with studs. Not sure exactly where from but they were Excess Un-Used. They may still have some studs??
From what I was told the reason for the insane price is they are Inconel.
Re: W9 headbolts [Re: Ck[FIN]] #1363607
01/03/13 06:59 PM
01/03/13 06:59 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
omygod, that is insane.
Re: W9 headbolts [Re: Ck[FIN]] #1363608
01/03/13 08:48 PM
01/03/13 08:48 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Way to go MoPaR!
That's only a little over $$33.00 apiece.
Unbeliveable!
Says, Material: Steel
Re: W9 headbolts [Re: Ck[FIN]] #1363609
01/03/13 09:00 PM
01/03/13 09:00 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: W9 headbolts [Re: sixpackgut] #1363610
01/03/13 10:11 PM
01/03/13 10:11 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: W9 headbolts [Re: WHITEDART] #1363611
01/03/13 10:47 PM
01/03/13 10:47 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got mine for a conventional W-9 from Ryan J and they were not cheap.
Even compared to regular ARP stuff.......then I had to replace the eight point nuts with the smaller 12 point on the studs in between the valve springs.
But I'm not complaining.........that was the cheap part of the deal.
Re: W9 headbolts [Re: tubtar] #1363612
01/03/13 10:49 PM
01/03/13 10:49 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I just looked at the Summit link.
OUCH !!!
I think I was into them for around 350.00
Re: W9 headbolts [Re: tubtar] #1363613
01/04/13 12:17 AM
01/04/13 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....god this stuff is FUN!!
Re: W9 headbolts [Re: tubtar] #1363614
01/04/13 12:29 AM
01/04/13 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I replace all of the nuts with 12 points...
and people think is cheap to build a W-9
Re: W9 headbolts [Re: Ck[FIN]] #1363615
01/04/13 02:22 AM
01/04/13 02:22 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Not cheap
http://www.summitracing.com/parts/dcc-5007912/overview/
pass the crack pipe, is that a typo?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: W9 headbolts [Re: Stroker Scamp] #1363616
01/04/13 03:02 AM
01/04/13 03:02 AM
DakFink Offline
DakFink  Offline
Not cheap
Afraid not!!
If I could figure out how to post pictures here I'd post some of the set I have.
They may list them as Steel BUT they aren't like any steel studs I've ever seen. They look and feel more like Titanium. But was told by another source they are suppose to be inconel.
Re: W9 headbolts [Re: DakFink] #1363617
01/04/13 04:40 AM
01/04/13 04:40 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: W9 headbolts [Re: SB449VALIANT] #1363618
01/04/13 05:55 AM
01/04/13 05:55 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Then it is a matter of common sense: measure the length, and buy something that is made for other brands and could fit. When you have an iron block you do not need the super special weight saving high$$$ stuff for superlight weight race. If you can use 1/2" for the big studs all the way, then try what fits Fords. I know some of the W9 alublock studs (mains?) use 1/2" UNC in block and is phased down to 7/16" UNF, probably to save weight. This means special design and special price, that you should not need. If you can run 1/2" through the boltholes in the head, then try again! And check that there is room for a washer and 1/2" UNF 12-point nut. My
Re: W9 headbolts [Re: SB449VALIANT] #1363619
01/04/13 08:10 AM
01/04/13 08:10 AM
DakFink Offline
DakFink  Offline
here's the pics of mine.
Re: W9 headbolts [Re: DakFink] #1363620
01/04/13 08:11 AM
01/04/13 08:11 AM
DakFink Offline
DakFink  Offline
2nd pic
