Is there an oval air cleaner for 1-4bbls? and.... #136347
10/14/08 05:05 PM
10/14/08 05:05 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I've heard the Air Grabber/Ramcharger air cleaners would work, but what parts would I need to have an oval air cleaner (like that of a six-pack or a Coyote Duster) over a single, say, Speed Demon or Edelbrock 4-bbl? Thanks.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136348
10/14/08 05:18 PM
10/14/08 05:18 PM
NH
72challorange Offline
He's Game
He's Game
NH
Like this?
I think it is a B=body baseplate.
Tom
By tdavist, shot with DSC-P72 at 2008-05-02
By tdavist, shot with DSC-P72 at 2008-03-22
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: 72challorange] #136349
10/14/08 07:30 PM
10/14/08 07:30 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
That will fit on a small block in an A-body?
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136350
10/14/08 07:35 PM
10/14/08 07:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I had one that I was going to put on my dart, but was told it would not clear the 2 speed wiper motor on the firewall. I never actually had a chance to test fit it since the car had no engine when I owned the air cleaner. No way in hell was I going to slice up a 1969 440 air grabber cleaner so I sold it and went with a round 1970 340 one instead.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: Neil] #136351
10/14/08 07:41 PM
10/14/08 07:41 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
If it could be confirmed that it would work, I'd have no problem buying a repro one from Year One or someone. But I want to make dang sure it fits first.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136352
10/14/08 07:46 PM
10/14/08 07:46 PM
Canada
CrAzYMoPaRGuY Offline
Canada
How come none of you guys are up closer to me? I would lend ya the one from my motorhome....
There are two different heights I believe, one for a 383 and a shorter one for a 440.....
CrAzYMoPaRGuY
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136353
10/14/08 07:58 PM
10/14/08 07:58 PM
NH
He's Game
He's Game
NH
Which part are you worried about?
This is a SB in an E-bod and 2 spd wiper motor.
Tom
There is a shorter element from K+N as well.
There is a member(torred4speed?) here who sells a fiberglass repro base here, it allows you to adjust the height by cutting the neck down to shorten it.
By tdavist, shot with DSC-P72 at 2008-04-24
By tdavist at 2008-05-01
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136354
10/14/08 08:38 PM
10/14/08 08:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Best there is for the NON OE crowd.
http://www.hybrid-fiberglass-solutions.com/
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: gtx6970] #136355
10/15/08 12:45 AM
10/15/08 12:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I can put my un-cut 383 air cleaner on my 340 GTS for a look.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: sharpie] #136356
10/15/08 09:29 AM
10/15/08 09:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There was a pic somewhere on here , thread about putting an air grabber setup in an A body that Scott Smith posted , the wiper motor on an A body sticks off to the side some so it's not as obtrusive as it is on a B body .
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: JohnRR] #136357
10/15/08 10:33 PM
10/15/08 10:33 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Unless you are running an air grabber box, I'd cut the seal area off the base to within flush of the air cleaner element.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: 375inStroke] #136358
10/15/08 10:43 PM
10/15/08 10:43 PM
Coeur d'Alene, ID
damnimcooltom Offline
Coeur d'Alene, ID
I have a fiberglass base and lid. Does anyone sell the hardware that attaches the base to the carb, and that holds the lid on?
This one will not fit under my 67 Dart hood as-is, but there is plenty I can grind off the bottom to make it fit if I decide to.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: damnimcooltom] #136359
10/15/08 10:47 PM
10/15/08 10:47 PM
tn
r69cuda Offline
r69cuda  Offline
tn
The air grabber will fit on an a-body. Here's mine.
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: r69cuda] #136360
10/16/08 05:14 AM
10/16/08 05:14 AM
NY
old340dog Offline
old340dog  Offline
NY
So these air cleaners will clear a 2 speed wiper motor in a 73 duster 340? Now all we neeed to do is figure out how to get rest of ram air setup mounted to bottom of hood.
old340dog
Re: Is there an oval air cleaner for 1-4bbls? and.... [Re: 375inStroke] #136361
10/16/08 08:36 AM
10/16/08 08:36 AM
JohnRR Offline
JohnRR  Offline
WHY ?
