SB motor plate for electric water pump #1357486
12/22/12 10:53 PM
12/22/12 10:53 PM
AndyF Offline OP
AndyF  Offline OP
I'm working on a SB powered A-body car at the moment. This one needed a motor plate and is going to run a remote water pump. I designed in a mount for a small racing alternator. The only trick is to use a Meziere water pump plate behind the motor plate. That makes it a bolt on setup without any machine work required to the stock housing.
Re: SB motor plate for electric water pump [Re: AndyF] #1357487
12/23/12 01:11 AM
12/23/12 01:11 AM
AndyF Offline OP
AndyF  Offline OP
An electric water pump will also fit just fine. Only trick is that you need to use a couple sets of gaskets since the backing plate needs gaskets and both sides of the motor plate. Bolts work fine but long studs would make it easier to put together and take apart.
Re: SB motor plate for electric water pump [Re: AndyF] #1357488
12/23/12 01:25 AM
12/23/12 01:25 AM
oregon
greendart408 Offline
oregon
Looks nice
Re: SB motor plate for electric water pump [Re: greendart408] #1357489
12/23/12 07:21 AM
12/23/12 07:21 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Thanks for sharing, I've had this image rolling around in my head for awhile lol
Re: SB motor plate for electric water pump [Re: SpareParts] #1357490
12/23/12 01:11 PM
12/23/12 01:11 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
if you left the hole out of the center you wouldn't need the Mezziere back plate & one less set of gaskets?
Re: SB motor plate for electric water pump [Re: Forest] #1357491
12/23/12 03:10 PM
12/23/12 03:10 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Re: SB motor plate for electric water pump [Re: Forest] #1357492
12/23/12 05:17 PM
12/23/12 05:17 PM
AndyF Offline OP
AndyF  Offline OP
No, unless you maching down the timing chain housing you need the Meziere back plate so the water flow will work correctly. This is a bolt on solution with the back plate then the motor plate and then the water pump.
Re: SB motor plate for electric water pump [Re: AndyF] #1357493
12/23/12 06:41 PM
12/23/12 06:41 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ran a solid no whole motorplate for years with a Meziere pump. All you are doing is sealing the water off. That empty cavity in the timing chain cover just fills up with water that basically never moves.
Re: SB motor plate for electric water pump [Re: Leon441] #1357494
12/23/12 06:49 PM
12/23/12 06:49 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Me too, not sure how that is any diferent than what the Meziere plate does?
Re: SB motor plate for electric water pump [Re: Forest] #1357495
12/23/12 06:59 PM
12/23/12 06:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
at least with the hole you could use it eather way with just a plate change, I like it.
Re: SB motor plate for electric water pump [Re: Forest] #1357496
12/23/12 11:47 PM
12/23/12 11:47 PM
AndyF Offline OP
AndyF  Offline OP
The Meziere plate is machined on the back side to block off the cavity area. It wouldn't matter if everything was perfectly balanced in the cooling system, but if one side of the engine has some extra flow resistance, all the water will go to the other side.
Re: SB motor plate for electric water pump [Re: AndyF] #1357497
12/23/12 11:53 PM
12/23/12 11:53 PM
AndyF Offline OP
AndyF  Offline OP
I made a small production run of the AN fittings. I couldn't find anyone selling these so I had to make my own. You can buy them all day long for Ford and Chevy motors, but I couldn't find anything for SB Mopar engines. I'll add them to my website just in case anyone else wants them.
Re: SB motor plate for electric water pump [Re: AndyF] #1357498
12/24/12 10:36 PM
12/24/12 10:36 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I have a race cover ,So mine would not need the hole I'm assuming.. It has the side inlets but for a electric pump it might need the two front holes.
Re: SB motor plate for electric water pump [Re: Dos Snails] #1357499
12/25/12 06:46 PM
12/25/12 06:46 PM
ohio
all spooled up Offline
ohio
nice moter plate but do you sell them
Re: SB motor plate for electric water pump [Re: all spooled up] #1357500
03/30/13 06:09 PM
03/30/13 06:09 PM
Chino Hills,Ca, USA
btroxler Offline
btroxler  Offline
Chino Hills,Ca, USA
They are being produced and sold as I write this. I just received mine. It is a really nice piece
Re: SB motor plate for electric water pump [Re: btroxler] #1357501
03/30/13 07:00 PM
03/30/13 07:00 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
On the race covers as in my pic there would be no need for the hole in the plate.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: SB motor plate for electric water pump [Re: Plumb Wired] #1357502
03/30/13 10:06 PM
03/30/13 10:06 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
but it still needs the transfer holes for the electric pump
Re: SB motor plate for electric water pump [Re: btroxler] #1357503
03/30/13 10:38 PM
03/30/13 10:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Do we have a price on these ? I would like to get one soon.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SB motor plate for electric water pump [Re: 1967dartgt] #1357504
03/31/13 12:13 AM
03/31/13 12:13 AM
AndyF Offline OP
AndyF  Offline OP
Hughes Engines will have them in stock. Should be the same price as the other AR Engineering motor plates. Part number is AR361 for the A-body version.
Re: SB motor plate for electric water pump [Re: AndyF] #1357505
04/02/13 10:47 PM
04/02/13 10:47 PM
Louisiana
Bignick Offline
Bignick  Offline
Louisiana
What about the low mount alt. kit for small block?
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
