SB motor plate for electric water pump
#1357486
12/22/12 10:53 PM
12/22/12 10:53 PM
Posts: 31,041 Oregon
AndyF
I'm working on a SB powered A-body car at the moment. This one needed a motor plate and is going to run a remote water pump. I designed in a mount for a small racing alternator. The only trick is to use a Meziere water pump plate behind the motor plate. That makes it a bolt on setup without any machine work required to the stock housing.
Re: SB motor plate for electric water pump
[Re: AndyF]
#1357487
12/23/12 01:11 AM
12/23/12 01:11 AM
AndyF
An electric water pump will also fit just fine. Only trick is that you need to use a couple sets of gaskets since the backing plate needs gaskets and both sides of the motor plate. Bolts work fine but long studs would make it easier to put together and take apart.
[Re: Forest]
#1357491
12/23/12 03:10 PM
12/23/12 03:10 PM
Posts: 1,745 Maryland
340_Dart
Maryland
if you left the hole out of the center you wouldn't need the Mezziere back plate & one less set of gaskets?
[Re: AndyF]
#1357493
12/23/12 06:41 PM
12/23/12 06:41 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Ran a solid no whole motorplate for years with a Meziere pump. All you are doing is sealing the water off. That empty cavity in the timing chain cover just fills up with water that basically never moves.
[Re: Leon441]
#1357494
12/23/12 06:49 PM
12/23/12 06:49 PM
Posts: 916 SE Washington
Forest
SE Washington
Me too, not sure how that is any diferent than what the Meziere plate does?
[Re: Forest]
#1357496
12/23/12 11:47 PM
12/23/12 11:47 PM
AndyF
The Meziere plate is machined on the back side to block off the cavity area. It wouldn't matter if everything was perfectly balanced in the cooling system, but if one side of the engine has some extra flow resistance, all the water will go to the other side.
[Re: AndyF]
#1357497
12/23/12 11:53 PM
12/23/12 11:53 PM
AndyF
I made a small production run of the AN fittings. I couldn't find anyone selling these so I had to make my own. You can buy them all day long for Ford and Chevy motors, but I couldn't find anything for SB Mopar engines. I'll add them to my website just in case anyone else wants them.
[Re: Plumb Wired]
#1357502
03/30/13 10:06 PM
03/30/13 10:06 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
On the race covers as in my pic there would be no need for the hole in the plate.
but it still needs the transfer holes for the electric pump
[Re: btroxler]
#1357503
03/30/13 10:38 PM
03/30/13 10:38 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Do we have a price on these ? I would like to get one soon.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: AndyF]
#1357505
04/02/13 10:47 PM
04/02/13 10:47 PM
Posts: 33 Louisiana
Bignick
Louisiana
What about the low mount alt. kit for small block?
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
