a milled Cylinder head question #1357334
12/22/12 08:27 PM
12/22/12 08:27 PM
Durham, NC
motomatt383 Offline OP
Durham, NC
I'm looking at a used set of 452 heads, lightly ported (gasket matched) nice valve springs retainers & all that stuff. my question is they have been surfaced, quite a bit it appears. 1 needs to be surfaced again. my concern is, is there a way to tell how much has been milled off them? I know small block Chevy heads have a target spot to measure off. do the Mopars have a spot like that?
Re: a milled Cylinder head question [Re: motomatt383] #1357335
12/22/12 09:53 PM
12/22/12 09:53 PM
Yes
The distance from the deck to the "closed" or shallow part of the open chamber is almost always near .100 thou give or take--good yardstick if there ever was one.
Re: a milled Cylinder head question [Re: ] #1357336
12/22/12 11:10 PM
12/22/12 11:10 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Use a mic and measure the lower head bolt outside flange area at one of the corners. The range in stock thickness can be from .995 to as much as 1.015 for stock heads that haven't been milled.
Measure both heads and post the readings. You need to measure both heads and if one head does need milled mill the other so you have both heads the same thickness when done.
MLR426
Re: a milled Cylinder head question [Re: MLR426] #1357337
12/23/12 12:52 AM
12/23/12 12:52 AM
Durham, NC
Durham, NC
both heads measure at .995-,993 pretty evenly across them. how far can they be safely milled then?
Re: a milled Cylinder head question [Re: motomatt383] #1357338
12/23/12 11:23 AM
12/23/12 11:23 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
A whole lot more
My 915's have a .110" angle mill plus a .025" straight cut on them
I'd say there's about .100" material left between the spark plug threads and the deck
Been it for years
Re: a milled Cylinder head question [Re: motomatt383] #1357339
12/23/12 09:10 PM
12/23/12 09:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How much is the seller asking for the heads ?
Re: a milled Cylinder head question [Re: MLR426] #1357340
12/23/12 09:42 PM
12/23/12 09:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
MLR426
this is correct. i've found the '906 heads to be 1.00 and the '452's maybe 1.1.
Re: a milled Cylinder head question [Re: lewtot184] #1357341
12/24/12 10:07 AM
12/24/12 10:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is there a similar measuring spot for small block cylinder heads?
Re: a milled Cylinder head question [Re: 360view] #1357342
12/28/12 03:09 PM
12/28/12 03:09 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Use same spot, lower corner head bolt boss.
I don't recall right off what the norm is for stock cast iron head thickness ?
MLR426
Re: a milled Cylinder head question [Re: roadhazard] #1357343
12/28/12 03:15 PM
12/28/12 03:15 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
A whole lot more
Been it for years
Now thats screwed up How does the intake fit ?
MLR426
Re: a milled Cylinder head question [Re: motomatt383] #1357344
12/28/12 03:20 PM
12/28/12 03:20 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
What are you trying to accomplish ? With what piston and what camshaft ? As John asked what is the price of the heads ? May be better options for you depending on price. They appear to be original thickness.
MLR426
Re: a milled Cylinder head question [Re: MLR426] #1357345
12/28/12 11:04 PM
12/28/12 11:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
A whole lot more
Been it for years
MLR426
It's been made to fit together
Only thing I worry about is performance. I make things work to get what I want if need be
Makes life interesting and I can't argue with the slips
