Re: a milled Cylinder head question
[Re: motomatt383]
#1357335
12/22/12 09:53 PM
12/22/12 09:53 PM
Yes The distance from the deck to the "closed" or shallow part of the open chamber is almost always near .100 thou give or take--good yardstick if there ever was one.
[Re: ]
#1357336
12/22/12 11:10 PM
12/22/12 11:10 PM
Posts: 4,799 ILL
MLR426
ILL
Use a mic and measure the lower head bolt outside flange area at one of the corners. The range in stock thickness can be from .995 to as much as 1.015 for stock heads that haven't been milled. Measure both heads and post the readings. You need to measure both heads and if one head does need milled mill the other so you have both heads the same thickness when done.
MLR426
[Re: motomatt383]
#1357338
12/23/12 11:23 AM
12/23/12 11:23 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
both heads measure at .995-,993 pretty evenly across them. how far can they be safely milled then?
A whole lot more
My 915's have a .110" angle mill plus a .025" straight cut on them I'd say there's about .100" material left between the spark plug threads and the deck Been it for years
[Re: MLR426]
#1357340
12/23/12 09:42 PM
12/23/12 09:42 PM
Posts: 3,916 usa
lewtot184
usa
MLR426
this is correct. i've found the '906 heads to be 1.00 and the '452's maybe 1.1.
[Re: 360view]
#1357342
12/28/12 03:09 PM
12/28/12 03:09 PM
Posts: 4,799 ILL
MLR426
ILL
Is there a similar measuring spot for small block cylinder heads?
Use same spot, lower corner head bolt boss. I don't recall right off what the norm is for stock cast iron head thickness ?
MLR426
[Re: roadhazard]
#1357343
12/28/12 03:15 PM
12/28/12 03:15 PM
Posts: 4,799 ILL
MLR426
ILL
A whole lot more
Now thats screwed up How does the intake fit ?
MLR426
[Re: motomatt383]
#1357344
12/28/12 03:20 PM
12/28/12 03:20 PM
Posts: 4,799 ILL
MLR426
ILL
What are you trying to accomplish ? With what piston and what camshaft ? As John asked what is the price of the heads ? May be better options for you depending on price. They appear to be original thickness.
MLR426
[Re: MLR426]
#1357345
12/28/12 11:04 PM
12/28/12 11:04 PM
roadhazard
Akron, Ohio U.S.A.
A whole lot more
MLR426
It's been made to fit together Only thing I worry about is performance. I make things work to get what I want if need be Makes life interesting and I can't argue with the slips
