Page 1 of 5 1 2 3 4 5
Small port w8? Update flow numbers #1349242
12/10/12 07:59 PM
12/10/12 07:59 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I just got a set of w8s to update intake port on it is by far the smallest intake port I have seen in a w8 casting.
I would love to know what they were run on.
Intake port 252cc. Port is 2.090" by 1.250"
SMALL!!!! ;-( Picture of my port vs the w8s
Re: Small port w8??? [Re: W5DART66] #1349243
12/10/12 08:20 PM
12/10/12 08:20 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
probably on a guys car that was sayin,this thing is slow for a w8 lol
Re: Small port w8??? [Re: W5DART66] #1349244
12/10/12 08:34 PM
12/10/12 08:34 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
15* Truck head I'm guessing...so maybe a really short track???
Re: Small port w8??? [Re: jim sciortino] #1349245
12/10/12 08:40 PM
12/10/12 08:40 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
It's not a truck head.
The small truck stuff was 2.160 by 1.360
Re: Small port w8??? [Re: W5DART66] #1349246
12/10/12 08:45 PM
12/10/12 08:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks like someone bought a set of raw castings and was unsure what to do with them. Wonder if it matches a commonly available gasket?!?
Re: Small port w8??? [Re: Al_Alguire] #1349247
12/10/12 08:46 PM
12/10/12 08:46 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I bought a sheetmetal intake one time that was run on a 290 inch motor. It was for W8 heads but very tiny ports.
Re: Small port w8??? [Re: Leon441] #1349248
12/10/12 09:37 PM
12/10/12 09:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
sound like they could have been on a very small motor with that small of a port. I wonder what size bore they where used on
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small port w8??? [Re: WHITEDART] #1349249
12/10/12 10:04 PM
12/10/12 10:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Virgin ports... Be gentle...
Re: Small port w8??? [Re: emarine01] #1349250
12/11/12 12:19 AM
12/11/12 12:19 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
More than likely it was used on a small displacement, high RPM, extremely efficient engine. 360 cubic inches or less. Bigger is not always better... Not to bash the OP, but I would take the top port over the bottom one any day of the week, chances are it is a very highly efficient, high velocity port with every aspect of it set up for a max effort combination. The short side radius is a lot bigger than the bottom port for sure. The bore size wouldn't be as critical with that port it as long as it was 4" or more.
Re: Small port w8??? [Re: stevet340] #1349251
12/11/12 12:35 AM
12/11/12 12:35 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I'd beg to difer...the op is the one who just did a set of junk heads from tx and helped the man run.5.50s w a baby cam junk intake
Re: Small port w8??? [Re: stevet340] #1349252
12/11/12 12:45 AM
12/11/12 12:45 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I am sorry but you just don't get it that top port has min cross section of 2.5 sq in this thing would not "RPM" on anything. High velocity port ?are we building dump trucks or race engines?
A PST 358. With w8 heads (CFE). Had min cross section of 3.2sq in.
A good NASCAR cup engine right now has min cross section of 3.8". I guess all the top engine builders have it wrong we need them darn high velocity ports.
I guess when I reworked Brian's small HVPs and took 20. Dur of duration out of the cam car picked up 1/2 sec and 8 mph.......
Oh and I am so glad that looking at port opening you can pick the "good port"
One of the reasons people that KNOW anything stopped posting here.....
Re: Small port w8??? [Re: W5DART66] #1349253
12/11/12 12:57 AM
12/11/12 12:57 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Very true
Re: Small port w8??? [Re: W5DART66] #1349254
12/11/12 01:10 AM
12/11/12 01:10 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Homogenous would be good starting point for port development
Sonic choke would be more for you to look into on your "high Velocity ports"
As RPM goes up demand in the intake port goes up = high air speed
It will not matter how "developed" a port is min and average cross section will become your limit as the port will go into sonic choke and HP and TQ will suffer
My port is developed as a good Homogenous port with Acceptable air speed for larger CI fast bracket car or high RPM small CI .
BTW. the head with large ports has been proven at making power this is just not some WAG.
Brett Miller
Re: Small port w8??? [Re: W5DART66] #1349255
12/11/12 08:40 AM
12/11/12 08:40 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: Small port w8??? [Re: stevet340] #1349256
12/11/12 06:29 PM
12/11/12 06:29 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
The last set of W8 heads for a small cubic inch Comp Eliminator engine were certainly not as small as those and flowed over 400cfm. The Cross sectional area would have been around 4". A 280ci engine at 9500 Rpm still needs around 3.65"
My old CFE heads had a minimum cross section of 3.48", below is a pic of the port window of the intake manifold as a reference
For whatever reason, I never took a pic of the intake face of them
The pic of the heads that Brett posted are curious, would I hazard a guess at an RPM limited road race application? It would be interesting to see how they look against an Edelbrock head, but I doubt that Brett has any of those in his shop
Alan Jones
Re: Small port w8??? [Re: LA360] #1349257
12/11/12 06:54 PM
12/11/12 06:54 PM
bronx n.y
O
O
bronx n.y
LOL true
Re: Small port w8??? [Re: W5DART66] #1349258
12/11/12 09:03 PM
12/11/12 09:03 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hey Brett do you think you can epoxy my W8s down to this HVP. I realy think this is what I need to make real power!!LOL You know CFE had no idea what they were doing.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small port w8??? [Re: 1967dartgt] #1349259
12/12/12 06:26 PM
12/12/12 06:26 PM
western PA
Sb Valiant Offline
Sb Valiant  Offline
western PA
IMO I think alot of people need to do there home work.. http://www.visnerengine.com/tech-basic-port-design.html
Re: Small port w8??? [Re: 1967dartgt] #1349260
12/12/12 06:32 PM
12/12/12 06:32 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: Small port w8??? [Re: fishy340] #1349261
12/12/12 06:33 PM
12/12/12 06:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
^^^^ small port heads
