Small port w8? Update flow numbers
#1349242
12/10/12 07:59 PM
12/10/12 07:59 PM
Posts: 1,784 PA
W5DART66
PA
I just got a set of w8s to update intake port on it is by far the smallest intake port I have seen in a w8 casting. I would love to know what they were run on. Intake port 252cc. Port is 2.090" by 1.250" SMALL!!!! ;-( Picture of my port vs the w8s
Re: Small port w8???
[Re: W5DART66]
#1349246
12/10/12 08:45 PM
12/10/12 08:45 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Looks like someone bought a set of raw castings and was unsure what to do with them. Wonder if it matches a commonly available gasket?!?
[Re: Al_Alguire]
#1349247
12/10/12 08:46 PM
12/10/12 08:46 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I bought a sheetmetal intake one time that was run on a 290 inch motor. It was for W8 heads but very tiny ports.
[Re: stevet340]
#1349252
12/11/12 12:45 AM
12/11/12 12:45 AM
Posts: 1,784 PA
W5DART66
PA
More than likely it was used on a small displacement, high RPM, extremely efficient engine. 360 cubic inches or less. Bigger is not always better... Not to bash the OP, but I would take the top port over the bottom one any day of the week, chances are it is a very highly efficient, high velocity port with every aspect of it set up for a max effort combination. The short side radius is a lot bigger than the bottom port for sure. The bore size wouldn't be as critical with that port it as long as it was 4" or more.
I am sorry but you just don't get it that top port has min cross section of 2.5 sq in this thing would not "RPM" on anything. High velocity port ?are we building dump trucks or race engines? A PST 358. With w8 heads (CFE). Had min cross section of 3.2sq in. A good NASCAR cup engine right now has min cross section of 3.8". I guess all the top engine builders have it wrong we need them darn high velocity ports.
I guess when I reworked Brian's small HVPs and took 20. Dur of duration out of the cam car picked up 1/2 sec and 8 mph.......
Oh and I am so glad that looking at port opening you can pick the "good port"
One of the reasons people that KNOW anything stopped posting here.....
[Re: stevet340]
#1349256
12/11/12 06:29 PM
12/11/12 06:29 PM
Posts: 6,137 Melbourne , Australia
LA360
The last set of W8 heads for a small cubic inch Comp Eliminator engine were certainly not as small as those and flowed over 400cfm. The Cross sectional area would have been around 4". A 280ci engine at 9500 Rpm still needs around 3.65" My old CFE heads had a minimum cross section of 3.48", below is a pic of the port window of the intake manifold as a reference
For whatever reason, I never took a pic of the intake face of them
The pic of the heads that Brett posted are curious, would I hazard a guess at an RPM limited road race application? It would be interesting to see how they look against an Edelbrock head, but I doubt that Brett has any of those in his shop
Alan Jones
[Re: LA360]
#1349257
12/11/12 06:54 PM
12/11/12 06:54 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
LOL true
[Re: W5DART66]
#1349258
12/11/12 09:03 PM
12/11/12 09:03 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Hey Brett do you think you can epoxy my W8s down to this HVP. I realy think this is what I need to make real power!!LOL You know CFE had no idea what they were doing.
Brett Miller W9 cnc'd heads STR Chassis fabraction
