408 stroker build - which windage tray? #1346117
12/04/12 09:55 PM
12/04/12 09:55 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Happy Birthday PAINT IT BLACK  Offline OP
Houston Texas
Is there a windage tray that will work out of the box with my 360 (5.9) Magnum block and a 4" stroke (Eagle crank)? If not, what are guys using? Thanks in advance.
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346118
12/04/12 10:35 PM
12/04/12 10:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think I used a moroso 360 tray and bent it till the thing fit right not the best but it works
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346119
12/05/12 12:09 AM
12/05/12 12:09 AM
Locomotion Offline
Locomotion  Offline
Crank scraper, preferably with a 7-8 qt. pan but running less than that. Scraper may need "fitting".
Ishihara-Johnson Crank Scrapers
Re: 408 stroker build - which windage tray? [Re: Locomotion] #1346120
12/05/12 12:36 AM
12/05/12 12:36 AM
PA
moparacer Offline
moparacer  Offline
PA
Moroso deep pan and no tray or scraper for me.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 408 stroker build - which windage tray? [Re: moparacer] #1346121
12/05/12 04:52 AM
12/05/12 04:52 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here.
Re: 408 stroker build - which windage tray? [Re: dartman366] #1346122
12/05/12 04:46 PM
12/05/12 04:46 PM
Houston Texas
Houston Texas
Do you guys use a different pickup tube in deep sump applications? I have a Milodon street, low profile 7 qt pan so it's not MUCH deeper than stock.
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346123
12/05/12 04:51 PM
12/05/12 04:51 PM
Houston Texas
Houston Texas
I read up on the benefits of a scraper and I already have decided to at least use a windage tray. This car gets essentially no track time but I misbehave quite frequently on the street. I typically run it up to 5800-6k every time I drive it, so oil is pretty sloshy on every outing.
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346124
12/05/12 05:19 PM
12/05/12 05:19 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Stay away from a tray on a little block. Robs power.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 408 stroker build - which windage tray? [Re: sixpackbee] #1346125
12/05/12 05:43 PM
12/05/12 05:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I tend to agree I've never seen any ET improvements with a tray or scraper on a small block, but I would think a mesh screen type tray could help some to catch some of the 'roping, I run a rear sump truck pan on mine though.
WIZE
In Car:
Re: 408 stroker build - which windage tray? [Re: Streetwize] #1346126
12/05/12 07:48 PM
12/05/12 07:48 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
8 quart pan w/6 qts of oil... seems to work fine with big fat alu rods
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346127
12/05/12 10:45 PM
12/05/12 10:45 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Kevco pan with built in scraper and no tray.
It's a good pan for the street since it does not sacrifice much ground clearance. Holds a couple more quarts than stock and has extensive baffling. Relatively cheap too.
I think the general consensus over the last few years is that windage trays are overrated.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 408 stroker build - which windage tray? [Re: dartman366] #1346128
12/05/12 10:53 PM
12/05/12 10:53 PM
owt west
Thread Ender1 Offline
owt west
Me too
Re: 408 stroker build - which windage tray? [Re: dartman366] #1346129
12/05/12 10:54 PM
12/05/12 10:54 PM
owt west
owt west
same here.
me too
Re: 408 stroker build - which windage tray? [Re: 471Magnum] #1346130
12/06/12 01:41 PM
12/06/12 01:41 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm using one on my 360. I think it set me back $230 and will be used on the 408 build (whenever I get around to that). 7qt, baffled, and doesn't sit any lower and than a factory pan.
Re: 408 stroker build - which windage tray? [Re: 471Magnum] #1346131
12/06/12 01:45 PM
12/06/12 01:45 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Have a picture of your pan? I run a kevko as well. and when I pulled it out of the box the sorry excuse for a crank scraper had me laughing out loud...Wondering if mine looks any different from yours? thanks
Re: 408 stroker build - which windage tray? [Re: mshred] #1346132
12/06/12 02:39 PM
12/06/12 02:39 PM
PA
moparacer Offline
moparacer  Offline
PA
The further you get the oil sump away from the crank the better, baffle it so you have oil control on acceleration and decel, and let it eat.
Re: 408 stroker build - which windage tray? [Re: moparacer] #1346133
12/06/12 04:12 PM
12/06/12 04:12 PM
Houston Texas
Houston Texas
Anyone have a pic of a properly baffled pan? My Milidon had some baffles, but they seem to be minimal.
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346134
12/06/12 04:23 PM
12/06/12 04:23 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
The Moroso pans are a good example......
I run no tray in my 408, 8 qt pan(5qts in it)......
In my 360 I will be running the same pan, but scraper and a modifided stock windage tray. I took a stock tray windowed it and welded in screens....
Re: 408 stroker build - which windage tray? [Re: 10.90 Racer] #1346135
12/06/12 06:01 PM
12/06/12 06:01 PM
Houston Texas
Houston Texas
Why would you run no oil control besides baffling on the 408 but do it on the 360? Just curious.
Re: 408 stroker build - which windage tray? [Re: PAINT IT BLACK] #1346136
12/06/12 06:08 PM
12/06/12 06:08 PM
Houston Texas
Houston Texas
Here's a pic of my Milodon. The pickup resides just fractions of an inch away from the bottom when installed. It seems to me that the motor will never starve for oil when subjected to any g forces, but I am still pondering foaming and oil adding to the rotating mass. The Morose pan seems to be constructed similarly, though I see they incorporate a provision for the dipstick (duh, Milodon!). The Moroso also seems to extend the baffling further inward, but not by much. I'd add that the Milodon pan is superior on the sides where the body of the pan extends further than the opening, creating some lateral baffling where the Moroso doesn't seem to have that feature.
I am open to anyone's input on this pan (I'd consider welding in more baffling if necessary), but I will say that I am not considering replacing the pan for another as I like this ones low profile and appearance and it fits great in my e body.... Though I found out it requires removal of both TTI headers to drop the pan (bummer!!!)
Note: I notched one baffle to allow room for my dip stick.
