Low mount alternator #1340302
11/23/12 10:19 PM
11/23/12 10:19 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
please post pic of low mount brackets with stock alternator and Ar Engineering engine plate on A-body.
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Low mount alternator [Re: Butch] #1340303
11/23/12 10:26 PM
11/23/12 10:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Jeg's SBC kit
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Low mount alternator [Re: hemi-itis] #1340304
11/23/12 10:28 PM
11/23/12 10:28 PM
hemi-itis Offline
hemi-itis  Offline
Another
Re: Low mount alternator [Re: Butch] #1340305
11/24/12 12:05 AM
11/24/12 12:05 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Here's mine Butch,not the best pic though
64 Plymouth Savoy
Dana 60
Re: Low mount alternator [Re: fourgearsavoy] #1340306
11/24/12 12:07 AM
11/24/12 12:07 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Does your adjustment bar come off the frame rail?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Low mount alternator [Re: Butch] #1340307
11/24/12 02:40 AM
11/24/12 02:40 AM
AndyF Offline
AndyF  Offline
I make a low mount kit that fits the PWM 8162 alternator. It isn't designed to work with a stock water pump though. To drive a stock water pump you'll need to space the alternator out a bunch.
The motor plates are all drilled on the back side for the low mount kit.
http://arengineering.com/products/motorplate-kit-powermaster/
Re: Low mount alternator [Re: AndyF] #1340308
11/24/12 03:06 AM
11/24/12 03:06 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Butch here is mine. Low mount setup, but no stock alt or AR Enginnnering motor plate.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Low mount alternator [Re: EvilB1Dart] #1340309
11/24/12 10:07 AM
11/24/12 10:07 AM
tboomer Online work
tboomer  Online Work
Wes...That looks like my DMI bracket..They work quite well!
Re: Low mount alternator [Re: Butch] #1340310
11/24/12 10:51 AM
11/24/12 10:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used this one from mancini's. I have the 120 denso so a little fitting
Lots of options
Re: Low mount alternator [Re: 1967dartgt] #1340311
11/24/12 11:29 AM
11/24/12 11:29 AM
Rittman Ohio
Rittman Ohio
Yes it is because it just seemed to work better that way
Gus
64 Plymouth Savoy
Dana 60
Re: Low mount alternator [Re: fourgearsavoy] #1340312
11/24/12 12:49 PM
11/24/12 12:49 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Mine is the DMI bracket with crank trigger.
Re: Low mount alternator [Re: Bigcube] #1340313
11/24/12 08:52 PM
11/24/12 08:52 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Thanks everyone. those are all great looking setups.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
Re: Low mount alternator [Re: Butch] #1340314
11/24/12 08:57 PM
11/24/12 08:57 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Do you have any pics. of your Duster ?
Any engine pics?
We are practically neighbors, I live in Aurora.
I have a 71 Demon I'm building.
Re: Low mount alternator [Re: demon440] #1340315
11/24/12 09:15 PM
11/24/12 09:15 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
mine
Re: Low mount alternator [Re: a493demon] #1340316
11/24/12 09:16 PM
11/24/12 09:16 PM
a493demon Offline
a493demon  Offline
#2
Re: Low mount alternator [Re: Butch] #1340317
11/24/12 11:34 PM
11/24/12 11:34 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Butch I just purchased a DMI low mount kit (not yet delivered) and will use it to low mount a mini alt. Not sure I will get it mocked up until early next year since I'm pulling the engine but once here you can come see it.
Russ
Re: Low mount alternator [Re: a493demon] #1340318
11/25/12 09:55 AM
11/25/12 09:55 AM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
What brand of bracket is that?
'74 Duster 440
'06 Pacifica
'78 MGB
Re: Low mount alternator [Re: Butch] #1340319
11/25/12 11:53 AM
11/25/12 11:53 AM
a493demon Offline
a493demon  Offline
Re: Low mount alternator [Re: max_maniac] #1340320
11/30/12 11:36 AM
11/30/12 11:36 AM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
I Russ
I ordered Andy's setup from Hughes Engines.I'm getting the bracket for the engine plate, a pulley and the wire harness. Rick 16lbhammer( Thanks so much Rick) gave me a Toyota alternator just like the one fourgearsavoy posted.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
Re: Low mount alternator [Re: Butch] #1340321
12/03/12 08:14 PM
12/03/12 08:14 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Got the alternator all mounted up. AR Engineering parts worked well.Alternator is a Toyota years '83 -'92, #14611 Nippondenso.
Weight is 10.6 lb, 70 Amp.
thanks Moparts for your help.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
