Low mount alternator
#1340302
11/23/12 10:19 PM
11/23/12 10:19 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
please post pic of low mount brackets with stock alternator and Ar Engineering engine plate on A-body.
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
Re: Low mount alternator
[Re: fourgearsavoy]
#1340306
11/24/12 12:07 AM
11/24/12 12:07 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Does your adjustment bar come off the frame rail?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Butch]
#1340307
11/24/12 02:40 AM
11/24/12 02:40 AM
Posts: 31,043 Oregon
AndyF
I make a low mount kit that fits the PWM 8162 alternator. It isn't designed to work with a stock water pump though. To drive a stock water pump you'll need to space the alternator out a bunch. The motor plates are all drilled on the back side for the low mount kit. http://arengineering.com/products/motorplate-kit-powermaster/
[Re: AndyF]
#1340308
11/24/12 03:06 AM
11/24/12 03:06 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Butch here is mine. Low mount setup, but no stock alt or AR Enginnnering motor plate.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: Bigcube]
#1340313
11/24/12 08:52 PM
11/24/12 08:52 PM
Butch
Tallmadge, Ohio
Thanks everyone. those are all great looking setups.
Butch
[Re: a493demon]
#1340318
11/25/12 09:55 AM
11/25/12 09:55 AM
Butch
Tallmadge, Ohio
What brand of bracket is that?
[Re: max_maniac]
#1340320
11/30/12 11:36 AM
11/30/12 11:36 AM
Butch
Tallmadge, Ohio
I Russ I ordered Andy's setup from Hughes Engines.I'm getting the bracket for the engine plate, a pulley and the wire harness. Rick 16lbhammer( Thanks so much Rick) gave me a Toyota alternator just like the one fourgearsavoy posted.
Butch
[Re: Butch]
#1340321
12/03/12 08:14 PM
12/03/12 08:14 PM
Butch
Tallmadge, Ohio
Got the alternator all mounted up. AR Engineering parts worked well.Alternator is a Toyota years '83 -'92, #14611 Nippondenso. Weight is 10.6 lb, 70 Amp. thanks Moparts for your help. Butch
