is 3/8" fuel line too much ? #1339845
11/23/12 12:03 AM
11/23/12 12:03 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
69 b-body with mostly stock 383. it will probably have around a 700 edelbrock carb.
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339846
11/23/12 12:11 AM
11/23/12 12:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Describe "To Much"
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339847
11/23/12 12:13 AM
11/23/12 12:13 AM
IN
ahy Offline
ahy  Offline
IN
3/8" is great. OE would have likley been 5/16". The 3/8 line will have a bit less restriction and help reduce the possibility of fuel problems with todays gas which boils easier since its made for pressurized EFI systems.
For an even more robust setup, add a return line and use the "3 prong" filter which returns any vapor and some gas gack to the tank. 1/4" is fine for the return line.
Re: is 3/8" fuel line too much ? [Re: ahy] #1339848
11/23/12 12:28 AM
11/23/12 12:28 AM
midwest
I
intragration Offline
I
midwest
I have a mid '80s car that originally came with a carbureted V6 and I was surprised to see that it had 3/8" lines. Your 383 should like it. The only concern may be with the original sending unit, if it has smaller fittings. When I put 3/8" lines on my 'Cuda, I also put in a new sending unit. If yours was originally 5/16", you may want to check this out too.
Re: is 3/8" fuel line too much ? [Re: intragration] #1339849
11/23/12 12:45 AM
11/23/12 12:45 AM
Shelby, Ohio
2
Shelby, Ohio
the sending unit is not an issue. i have not ordered it yet. thanks for the info.
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339850
11/23/12 01:37 AM
11/23/12 01:37 AM
Don't forget that the size is the outside diameter, not the inside diameter My 1/2 inch aluminum line is a little over 3/8 I.D.
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339851
11/23/12 01:51 AM
11/23/12 01:51 AM
Actually finding a sending unit that reads correctly is going to be the main problem. Do your homework as there's been a ton of issues with them. With your eng a 5/16 will be more than plenty but I'd go with 3/8 as you might swap in a stroked 440 in the future . Also a 1/4 return line to the tank so the fuel never deadheads along with a properly sized orifice restriction for psi management. A 3 prong filter with the right orifice will work with your current requirements
Re: is 3/8" fuel line too much ? [Re: RapidRobert] #1339852
11/23/12 11:26 AM
11/23/12 11:26 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
nah 3/8 is what I'd minimally run on any old V8. Can't hurt anything.
I run a 1/2" hardline up to my filter then mechanical pump, then go out 3/8 to everything else (Keeping the volume more than adequate on the intake side of the pump is also a good idea - think I read that on a RobbMc article). The 3/8 turns into 1/2" again at the carb. Pics (want to brag... just got this all installed - note the modded Holley adjustable cable bracket/return (I love symmetry - that was a treat). This is on a 408 with Al heads.
Re: is 3/8" fuel line too much ? [Re: PAINT IT BLACK] #1339853
11/23/12 11:28 AM
11/23/12 11:28 AM
Houston Texas
Houston Texas
Sorry to hijak, just excited with new toys.
Re: is 3/8" fuel line too much ? [Re: PAINT IT BLACK] #1339854
11/23/12 11:29 AM
11/23/12 11:29 AM
Houston Texas
Houston Texas
Last one.
Really.... 3/8 lines. No sweat. But look for bottle necks in fittings/sending unit, etc. Some NPT fittings you may have to drill out to get a true diameter like I did on my 1/2" feed to the Carter pump. It takes a 1/4" NPT (fittings a 1/4"NPT M to -8 M , but that's huge enough to drill quite a bit out on the NPT side and get the inside diameter close to the feed line, which is -8 AN.
Re: is 3/8" fuel line too much ? [Re: intragration] #1339855
11/23/12 11:35 AM
11/23/12 11:35 AM
Houston Texas
Houston Texas
Was a pain for me to find my 1/2" fitting sending unit... I kinda get the feeling no one really runs a mechanical pump with a 1/2" feed... Oh well, dare to be different. Then get out your wallet.
Re: is 3/8" fuel line too much ? [Re: PAINT IT BLACK] #1339856
11/23/12 11:39 AM
11/23/12 11:39 AM
Shelby, Ohio
2
Shelby, Ohio
clean looking set-up. one other question, can i use brake line as my return line ? i have boxes of that already. what is the difference between brake line and fuel line ??
Re: is 3/8" fuel line too much ? [Re: ahy] #1339857
11/23/12 12:22 PM
11/23/12 12:22 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
That's a nice thought but its wishful thinking at best , BTDT
Adding the return line and an electric pump is the best avenue to try to deal with the fuel issue .
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339858
11/23/12 07:00 PM
11/23/12 07:00 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Mostly stock 383? With this setup a 3/8" line is more than adequate.
Re: is 3/8" fuel line too much ? [Re: 2abodymcodes] #1339859
11/24/12 12:12 AM
11/24/12 12:12 AM
IN
ahy Offline
ahy  Offline
IN
I would think brake line would be fine for the return if you have 1/4" diameter.
