Re: is 3/8" fuel line too much ?
[Re: intragration]
#1339855
11/23/12 11:35 AM
11/23/12 11:35 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I have a mid '80s car that originally came with a carbureted V6 and I was surprised to see that it had 3/8" lines. Your 383 should like it. The only concern may be with the original sending unit, if it has smaller fittings. When I put 3/8" lines on my 'Cuda, I also put in a new sending unit. If yours was originally 5/16", you may want to check this out too.
Was a pain for me to find my 1/2" fitting sending unit... I kinda get the feeling no one really runs a mechanical pump with a 1/2" feed... Oh well, dare to be different. Then get out your wallet.
[Re: ahy]
#1339857
11/23/12 12:22 PM
11/23/12 12:22 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
3/8" is great. OE would have likley been 5/16". The 3/8 line will have a bit less restriction and help reduce the possibility of fuel problems with todays gas which boils easier since its made for pressurized EFI systems.
For an even more robust setup, add a return line and use the "3 prong" filter which returns any vapor and some gas gack to the tank. 1/4" is fine for the return line.
That's a nice thought but its wishful thinking at best , BTDT
Adding the return line and an electric pump is the best avenue to try to deal with the fuel issue .
[Re: 2abodymcodes]
#1339859
11/24/12 12:12 AM
11/24/12 12:12 AM
Posts: 7,664 IN
ahy
IN
clean looking set-up. one other question, can i use brake line as my return line ? i have boxes of that already. what is the difference between brake line and fuel line ??
I would think brake line would be fine for the return if you have 1/4" diameter.
