rust remover? #1330859
11/04/12 10:02 PM
11/04/12 10:02 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
Was wondering what's a cheap rust remover or something I can let parts get dipped into to remove rust. What was the molasses mixture I heard of.
thanks kurt
Re: rust remover? [Re: kams] #1330860
11/04/12 10:19 PM
11/04/12 10:19 PM
NW Pennsylvania
areibel Offline
areibel  Offline
NW Pennsylvania
I don't know about the molasses one, but I tried this one and it works-
https://board.moparts.org/ubbthreads/show...part=1&vc=1
I used two gallons of vinegar and the right amounts of salt and lemon juice, I put it in a big plastic tub. I was able to clean quite a bit before it seemed to loose effectiveness. One tip, I'd let the stuff soak for a couple hours, then pull it out and use a cheap paint brush to knock the sludge off. It seems likeit speeds it up a bit?
Re: rust remover? [Re: areibel] #1330861
11/04/12 10:28 PM
11/04/12 10:28 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
Use this stuff.
Probably not "cheap" in your thinking, but quite effective in removing rust from parts.
http://www.rustremover.net/
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: rust remover? [Re: hemi71x] #1330862
11/05/12 12:18 AM
11/05/12 12:18 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I recently tried some evapo-rust on an old rusty humming bird feeder my Mom has. Not deep pitted rust, but, thick enough rust that a wire brush was of little use.
All I can say is WOW! Left a part soaking in evapo-rust overnight, and it came out like new......
I wasn't able to fully submerse the part, so you can easily see 'before and after'.
John
Re: rust remover? [Re: SattyNoCar] #1330863
11/05/12 12:49 AM
11/05/12 12:49 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I have used and am happy with Evaporust, except I've got too much rusty stuff!
Try over on the HAMB for the molasses deal. Seems that many swear by it, but it's gotta be done over time and it STINKS!
Re: rust remover? [Re: RodStRace] #1330864
11/05/12 01:00 AM
11/05/12 01:00 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I am VERY happy with the way Evaporust removes rust, even REALLY bad rust will disolve away completely in a day or two. However, I am unhappy with the relatively short life it has, I have gone through over 10 gallons of it derusting parts from one car (dash stuff, suspension parts, etc.). So it's pretty expensive. I have started to shop around for a similar but more cost effective product and found this stuff Un-Rust It promises the same type of safe removal (only removes rust, will not etch, pit, or otherwise remove or damage good metal like acid baths can do). I ordered some today, we'll see how it goes.
Re: rust remover? [Re: areibel] #1330865
11/05/12 01:49 AM
11/05/12 01:49 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
This mixture works great. I mix it up in a 5 gallon bucket, about 3-1/2 gallons at a time. I seems to have a very long "shelf life" and I have cleaned a lot of parts without it losing much strength. I let stuff sit anywhere from 24 hours to 2 or 3 days when the weather is much cooler. I dont think it could get more cost effective for rust cleaning
Re: rust remover? [Re: nomore65BelvJim] #1330866
11/05/12 01:55 AM
11/05/12 01:55 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: rust remover? [Re: forphorty] #1330867
11/05/12 02:08 AM
11/05/12 02:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Personally I don't find many uses for acid because of the finish it leaves on metal (etched or pitted) but if you want to use acid why not use the good stuff? buy some Muratic acid (swimming pool acid) it's cheap and works fast, it will remove most rust in minutes not days, and will leave the same surface finish as the vinigar does, just a whole lot faster, It's dirt cheap too.
Re: rust remover? [Re: ScottSmith_Harms] #1330868
11/05/12 02:22 AM
11/05/12 02:22 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Try using in your garage and watch every loose piece of iron in there develop a nice red covering of rust. Sorry, but no thanks.
Re: rust remover? [Re: John Brown] #1330869
11/05/12 02:51 AM
11/05/12 02:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I know better than that Not to mention (as I already did) I don't like using ANY type of acid for rust removal, too many good non acid choices these days to resort to that in most circumstances.
Re: rust remover? [Re: ScottSmith_Harms] #1330870
11/05/12 04:06 AM
11/05/12 04:06 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I don't like using ANY type of acid for rust removal.
Since the ph of evaporust is 6.1, per msds, it's acidic and should be avoided... correct?
Re: rust remover? [Re: RobX4406] #1330871
11/05/12 12:58 PM
11/05/12 12:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Semantics......Bottom line is that Evaporust wont etch, pit, or otherwise remove good metal, viniger, citric acid, and muratic acid will.
Re: rust remover? [Re: ScottSmith_Harms] #1330872
11/05/12 01:24 PM
11/05/12 01:24 PM
RobX4406 Offline
RobX4406  Offline
Aren't any semantics in reading or comprehending your statement.
Evaporust is an acid as it's 6.1 ph is less than 7. Because evaporust is an acid, by your own statement, it should be avoided.
What is the next song you would like queued up?
Re: rust remover? [Re: RobX4406] #1330873
11/05/12 01:35 PM
11/05/12 01:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Rob....Are you just bored or what?
Re: rust remover? [Re: ScottSmith_Harms] #1330874
11/05/12 02:16 PM
11/05/12 02:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Scott, just a little word of advise. When using EvapoRust, make sure you submerge the part completely. Don't just dip one section of the part.
I dipped one end of a part in EvapoRust once. When I removed the part, there was a shallow groove eaten into the part at the dip line.
Re: rust remover? [Re: burdar] #1330875
11/05/12 02:26 PM
11/05/12 02:26 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I have used the muriatic acid on small parts and it works great. I rinse it well afterwards with water. I would not use the stuff on a large scale because it is nasty to work with and sure hurts on the skin. Buy why not just neutralize the parts with something like baking soda afterwards? Baking soda and an extra bucket are cheap.
Re: rust remover? [Re: Tom_440] #1330876
11/05/12 03:22 PM
11/05/12 03:22 PM
Muriatic acid is too dangerous and agressive for me to use it comfortably. With the vinegar/lemon juice/salt mix I dont have to wear rubber gloves, be particularly concerned about splash or using it in an enclosed area. Disposal is not an issue for it either.
I make a 3-1/2 gallon batch for under $10. Lasts for months.
Re: rust remover? [Re: nomore65BelvJim] #1330877
11/05/12 04:12 PM
11/05/12 04:12 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I'm very interested in this thread/topic. For years, I always did this;
- 1) mechanically removed rust; wire brush/wire wheel/sandpaper or sandblasting (if feasible)
- 2) etch/convert the surface with acid or one of the "phosphate" type converters.
- 3) cover with primer/paint to prevent moisture and oxygen from reaching the metal.
....BUT, it seems with all the products and all the hype/claims, it is VERY hard to determine what is the best product(s) to use. Like many people, I don't really care what it costs; whatever the cost, it's cheap compared to cutting, welding and rust repair.
Here's some links I found;
http://www.drjing.com/Mini/BLOG/SideBySide.htm
http://www.thesamba.com/vw/forum/viewtop...sc&start=40
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: rust remover? [Re: RodStRace] #1330878
11/05/12 05:11 PM
11/05/12 05:11 PM
Midwest
Chargerfan Offline
Chargerfan  Offline
Midwest
Sounds like naval jelly.
2011 Challenger R/T
2017 Ram 1500 BIG HORN Edition
