Personally I don't find many uses for acid because of the finish it leaves on metal (etched or pitted) but if you want to use acid why not use the good stuff? buy some Muratic acid (swimming pool acid) it's cheap and works fast, it will remove most rust in minutes not days, and will leave the same surface finish as the vinigar does, just a whole lot faster, It's dirt cheap too.
