400 Flywheel #132830
10/06/08 10:12 AM
10/06/08 10:12 AM
Ontario, Canada
jrn88 Offline OP
jrn88  Offline OP
Ontario, Canada
I have a 1972 400 and I want to put it in my Fury with a 4 speed Tranny ....I believe the 400 is externally balanced is there a specific flywheel for a 400 or do I need to just get one balanced?
Re: 400 Flywheel [Re: jrn88] #132831
10/06/08 12:41 PM
10/06/08 12:41 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The 400/440 cast crank share the same flywheel. Give us a call, we can balance one for you.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 400 Flywheel [Re: 64dodge572] #132832
10/07/08 01:16 AM
10/07/08 01:16 AM
dogdays Offline
dogdays  Offline
Be sure you have a cast crank before you look for a flywheel.
R.
Re: 400 Flywheel [Re: dogdays] #132833
10/07/08 09:41 PM
10/07/08 09:41 PM
Ontario, Canada
jrn88 Offline OP
jrn88  Offline OP
Ontario, Canada
How do I know if it is a cast crank or not?
Re: 400 Flywheel [Re: jrn88] #132834
10/07/08 11:28 PM
10/07/08 11:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Balancer on front of engine should say Cast Crank Only or something like that on it.
Re: 400 Flywheel [Re: DaytonaTurbo] #132835
10/08/08 12:14 AM
10/08/08 12:14 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I thought there was a template in the archives for drilling a neutral flywheel, so it will work
Re: 400 Flywheel [Re: dave571] #132836
10/08/08 12:51 AM
10/08/08 12:51 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
one of my buddies has a factory 400 cu.in. 4 speed mudder truck with a factory steel crank. I've been told they used the steel 383 cranks for this purpose until they were used up.
Re: 400 Flywheel [Re: DaytonaTurbo] #132837
10/08/08 12:55 AM
10/08/08 12:55 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
is not on 400 on a 440 yes
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 400 Flywheel [Re: 440beep] #132838
10/08/08 12:59 AM
10/08/08 12:59 AM
Manitoba, Canada
Manitoba, Canada
Really, I thought they would have used the same? If not, I think 440source.com has as nice page showing off all the factory big block balancers.
Re: 400 Flywheel [Re: jrn88] #132839
10/08/08 01:02 AM
10/08/08 01:02 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
#3614374, used on 400's with external balance cast cranks, which can usually be found in a passenger car and/or automatic trans application (applications with 400 engines and manual transmission applications used forged cranks.) It measures 7 1/4" diameter by about 7/8" wide. Although it is similar to the "six pack" dampers above, the weight on these is much thicker, and more closely resembles the weights on the cast crank 440 models below, even though the ring thickness is similar to an internal balance damper. One easy way to identify these (and not confuse them with six pack models) is the small half circle that is cut into one side of the counterweight. This is visible in the picture above at about the 3 o'clock position. This is the only damper that will have this small cut.
all 72-74 400 4speed cars are factory steel cranks
damper 3614371damper
Re: 400 Flywheel [Re: 440beep] #132840
10/08/08 01:05 AM
10/08/08 01:05 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
400 cast crank balancer
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 400 Flywheel [Re: moparmarks] #132841
10/08/08 01:06 AM
10/08/08 01:06 AM
moparmarks Offline
moparmarks  Offline
400 forged crank balancer
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 400 Flywheel [Re: moparmarks] #132842
10/08/08 01:11 AM
10/08/08 01:11 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
for the pics
Re: 400 Flywheel [Re: dave571] #132843
10/08/08 08:40 AM
10/08/08 08:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is but that is a PRECISE operation , ESPECIALLY if someone is doing it AFTER an engine was balanced using something else . How many people have a rotary table for thier HOME drill press .... don't all stand up at once
YMMV
Re: 400 Flywheel [Re: JohnRR] #132844
10/08/08 12:59 PM
10/08/08 12:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
sorry the highjack, but being the diff balancer dampeners came out to float!!!
are the PULLEYS to both dampeners diff ?
I mean of a 4 grooves pulley to cast assembly is the same than a 4 grooves pulley to forged assembly ?
Re: 400 Flywheel [Re: NachoRT74] #132845
10/08/08 01:24 PM
10/08/08 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
pulleys are neutral and not balancer specific EXCEPT for the bolt circle change from asymmetric to symmetric around 1971 , or was it 1970 ??? ...
Re: 400 Flywheel [Re: JohnRR] #132846
10/08/08 02:31 PM
10/08/08 02:31 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Modern devices have spoiled creativity, a protractor and 12-inch scale would do the job equally well.
Re: 400 Flywheel [Re: John_Kunkel] #132847
10/08/08 02:54 PM
10/08/08 02:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 400 Flywheel [Re: JohnRR] #132848
10/11/08 02:02 PM
10/11/08 02:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
ok, fine but I mean if because the diff thickness of balancer dampeners makes some differences on pulley deep, not really because some balancing on pulley.
Re: 400 Flywheel [Re: John_Kunkel] #132849
10/11/08 04:09 PM
10/11/08 04:09 PM
dave571 Offline
dave571  Offline
and doing it from the diagram or any other method with care at home, and it will be AT LEAST as close as the factory balance was, AND as good as a reman torque converter from a rebuilder who welded the weights on himself.
