Quickest SBM's on Moparts running SDSS Stage 2 Eddies? #1324853
10/23/12 10:29 AM
10/23/12 10:29 AM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Trying to decide whether to sell my great set of SDSS Stage 2 Edelbrocks, upgrade them or just save them for another project. I think there are more a few guys in the 10's with these heads, so who'se out there are what did you run? I know Flyfish is in the high 10's with his awesome second gen Cuda notch, but I think there are several others as well.
I'm looking to build a high torque 318 or 360 based tow motor to put in either a LWB dakota or maybe an older B body sedan that I could reuse these heads on but they're kind of overkill for that.
Thanks!
WIZE
In Car:
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324854
10/23/12 01:45 PM
10/23/12 01:45 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
10.60 on motor 9.60 on .073 nitrous jet. 340 block, 3.65 crank, eddies, pump gas.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: 1967dartgt] #1324855
10/23/12 03:50 PM
10/23/12 03:50 PM
Weddington, N.C.
Weddington, N.C.
That's impressive power, how high do you spin it and what cam/compression is that?
WIZE
In Car:
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324856
10/23/12 04:42 PM
10/23/12 04:42 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
10.86 @122 in my 68 notch. Full interior and all motor.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324857
10/23/12 09:15 PM
10/23/12 09:15 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would shift at 6800, old crowler solid roller 604 out of the catalog, and it was 11.5. Pump gas on the street and track and mix some 112 on the spray to be safe. Miss that motor took it apart to go to a 4in crank, sold heads and went with batten w2 then 360-1 heads.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: 1967dartgt] #1324858
10/23/12 09:17 PM
10/23/12 09:17 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That was also with a full interior, factory buckets and 3450 raceweight.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324859
10/23/12 09:26 PM
10/23/12 09:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Quickest SBM or tow motor?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Adobedude] #1324860
10/23/12 10:12 PM
10/23/12 10:12 PM
Weddington, N.C.
Weddington, N.C.
Lol, i tend to reuse my stuff for a variety of purposes. My 414 has Mahle pistons which are great but they don't have very deep valve pockets. So I'm looking to upgrade the heads with a bigger/better flowing port window and keep the cam I have., so I either need to sell these or reuse them on something else.
These heads are great but (short of changing pistons) I really don't think I can wring them out to their maximum potential. Way Too good to sit on the shelf.
WIZE
In Car:
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324861
10/24/12 11:20 AM
10/24/12 11:20 AM
Weddington, N.C.
Weddington, N.C.
I checked with Mahle Tech and it turns out the Valve pockets on their standard 4.00" stroke pistons are .250" deep and cut at 2.17" valve relief which means they can take both a bigger valve and a higher lift cam than I originally thought they did. That's good news in that they'll swallow AT LEAST a 2.08" intake valve without issue.
Maybe I'll tweak the heads some more, but being these SDSS stage 2's are good for 550+ as they are they might be better to leave them as is and find another more suitable app....like another 7800 RPM 340
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324862
10/24/12 11:48 AM
10/24/12 11:48 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My old Duster with Hensley stage 2 eddies( peaked at 274) ran 10.70's at 3400 pounds with a flat tappet. 416 motor.
Full interior,all steel, bench seat, 300 pound driver, yada, yada. Small tube headers, weiand excellerator, 727 trans, super stock leafs.
Made 70 mile round trip jaunts to the track in this configuration.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: B3422W5] #1324863
10/24/12 12:38 PM
10/24/12 12:38 PM
Central NC
gch Offline
gch  Offline
Central NC
You will regret selling them.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324864
10/24/12 02:10 PM
10/24/12 02:10 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I'm certainly not the fastest, but with SDSS Eddies and 418 cid and pump 93 octane. My challenger went 10.87 at 121 mph at 3720 with driver.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: 416challenger] #1324865
10/24/12 08:48 PM
10/24/12 08:48 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
9.997@132 2835 lbs on the line. 70 Dart Swinger
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: DragDart360] #1324866
10/24/12 08:54 PM
10/24/12 08:54 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
I would say but then I got to kill yah. Lol
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: one bad fish] #1324867
10/25/12 09:17 AM
10/25/12 09:17 AM
Weddington, N.C.
Weddington, N.C.
DragDart...is that all motor?
High 9's @ 132....That's really impressive MPH for that weight
WIZE
In Car:
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324868
10/25/12 02:10 PM
10/25/12 02:10 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Wize, they are a pretty decent pair of heads for the price and using stock rockers, etc. My Eddy's are home ported and are more than enough for me..
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: TheOtherDodge] #1324869
10/25/12 03:39 PM
10/25/12 03:39 PM
Weddington, N.C.
Weddington, N.C.
I LOVE the pair I have, and in the Rocky I've only scratched the surface of the mid-high 10 potential of them for this car.
Where I am at right now is I want to transition to an E85 carb and I'd really like to swap to a head with more port volume to compansate for the lower A/F ratio ( more fuel displaces more of the available port left for the air to get in). I have another set of heads on the way to play with and with my limited time to play I'm debating what's best to do with them....namely, keep them as is for another project, upgrade them (like Brian did on his Car Craft 414).... or let somebody else enjoy them.
WIZE
In Car:
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: Streetwize] #1324870
10/25/12 10:07 PM
10/25/12 10:07 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
All motor, Ryan did a great job on the heads and cam selection
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: DragDart360] #1324871
10/25/12 11:01 PM
10/25/12 11:01 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
My 410 Dr J ported eddy heads went 10.56@125.4 with a 3450lb race weight. It's a 11.8 compression motor on E85. It dynoed 581HP with the factory hyd roller set up.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Quickest SBM's on Moparts running SDSS Stage 2 Eddies? [Re: DragDart360] #1324872
10/26/12 12:12 AM
10/26/12 12:12 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
[Email]9.997@132[/Email] 2835 lbs on the line. 70 Dart Swinger [/
quote]
DragDart that is very impressive. What are your 60 ft. and 1/8 mile times? Thanks..... Sorry for the hijack..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
