Mopar cast aluminum valve cover, which pcv? #1322208
10/18/12 10:23 AM
10/18/12 10:23 AM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, I picked up a set of mopar bb cast aluminum valve covers and the recommended grommets. Now I can't find a pcv that will fit. What are you guys using with these valve covers? Thanks
Re: Mopar cast aluminum valve cover, which pcv? [Re: 70VcodeCoronetRT] #1322209
10/18/12 02:10 PM
10/18/12 02:10 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Here is the supposedly correct, stock PCV valve.
http://www.classicindustries.com/mopar/parts/pcv180.html
I think I used one similar, although I have the same setup as you. If you have a decent speed shop, or even just an OReillys around where you live, I suggest you bring your valve cover and grommet there and try out what they have until you find one that fits.
Re: Mopar cast aluminum valve cover, which pcv? [Re: 70VcodeCoronetRT] #1322210
10/19/12 12:03 PM
10/19/12 12:03 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Any 3/4" pcv valve from a mid '70s GM V8 will work.
Rich H.
Esse Quam Videri
Re: Mopar cast aluminum valve cover, which pcv? [Re: 70VcodeCoronetRT] #1322211
10/19/12 10:50 PM
10/19/12 10:50 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I bought billet breathers for my Jensen with MP aluminum valve covers, one has a built in PCV valve....
CrAzYMoPaRGuY
Re: Mopar cast aluminum valve cover, which pcv? [Re: GreenBird] #1322212
10/19/12 10:54 PM
10/19/12 10:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I cheated... A little work with a mill and the stock Mopar grommet fits great... Which means the stock PCV valve fits perfectly.. The stock push-in style breather works in one of the oil filler locations too...
Re: Mopar cast aluminum valve cover, which pcv? [Re: 1_WILD_RT] #1322213
10/20/12 12:16 AM
10/20/12 12:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And...
Re: Mopar cast aluminum valve cover, which pcv? [Re: 1_WILD_RT] #1322214
10/20/12 12:48 AM
10/20/12 12:48 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Summit has the MP grommets for 12.95. Uses a stock pcv..
I am truckless..
Re: Mopar cast aluminum valve cover, which pcv? [Re: 340SHORTY] #1322215
10/20/12 08:30 AM
10/20/12 08:30 AM
IN
ahy Offline
ahy  Offline
IN
On mine, I tried several valves and couldn't find one that would stay in reliably. I fabbed a sheet metal strap to go over the top of the valve. It is held in place by two short needle point screws in the rubber of the grommet. No problem now.
Re: Mopar cast aluminum valve cover, which pcv? [Re: ahy] #1322216
10/20/12 09:15 AM
10/20/12 09:15 AM
Nebraska
Nebraska
Thanks guys. I put in the recommended grommets. And the factory PCV does not work with them. It's too big. I'll give a GM one a try.
