Re: Mopar cast aluminum valve cover, which pcv?
[Re: 70VcodeCoronetRT]
#1322209
10/18/12 02:10 PM
10/18/12 02:10 PM
Posts: 64 Iowa
GreenBird
Iowa
Here is the supposedly correct, stock PCV valve. http://www.classicindustries.com/mopar/parts/pcv180.html I think I used one similar, although I have the same setup as you. If you have a decent speed shop, or even just an OReillys around where you live, I suggest you bring your valve cover and grommet there and try out what they have until you find one that fits.
#1322210
10/19/12 12:03 PM
10/19/12 12:03 PM
Posts: 17,850 S.E. Michigan
ZIPPY
S.E. Michigan
Any 3/4" pcv valve from a mid '70s GM V8 will work.
Rich H.
Esse Quam Videri
#1322211
10/19/12 10:50 PM
10/19/12 10:50 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I bought billet breathers for my Jensen with MP aluminum valve covers, one has a built in PCV valve....
CrAzYMoPaRGuY
[Re: GreenBird]
#1322212
10/19/12 10:54 PM
10/19/12 10:54 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I cheated... A little work with a mill and the stock Mopar grommet fits great... Which means the stock PCV valve fits perfectly.. The stock push-in style breather works in one of the oil filler locations too...
[Re: 1_WILD_RT]
#1322214
10/20/12 12:48 AM
10/20/12 12:48 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Summit has the MP grommets for 12.95. Uses a stock pcv..
I am truckless..
