Page 1 of 3 1 2 3
GM metric rear disc conversion #1313394
09/30/12 08:57 PM
09/30/12 08:57 PM
MN
JERICOGTX Online content OP
JERICOGTX  Online Content OP
MN
For those that have done the GM metric caliper rear disc conversion, what rotors are you using? Those from a Jeep or Ford Explorer?
Thanks.
Jeff
69 GTX 68 Road Runner
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313395
09/30/12 09:09 PM
09/30/12 09:09 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Thanks.
Jeff
hey Jeff i would be interested in hearing about the hole set up. i mean like what all parts you use etc.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: GM metric rear disc conversion [Re: mopar65] #1313396
09/30/12 09:19 PM
09/30/12 09:19 PM
MN
MN
Well from what I know you use the front caliper from a mid 80's GM "metric" body style ie Monte Carlo, rear rotors from either a Jeep Cherokee, or 2000 Ford Eplorer. You also need caliper brackets from Speedway. The brackets can also be bought on eBay. The brackets need to be welded on the rear housing. Over all you can install rear disc brakes for around $200, IF you shop around for parts. Rockauto, and eBay seem to have the best prices.
Jeff
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313397
09/30/12 09:24 PM
09/30/12 09:24 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Jeff I used rotors from a Jeep Grand Cherokee with GM metric calipers and brakes from any circle track shop for the rear.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313398
09/30/12 09:43 PM
09/30/12 09:43 PM
mopar65 Offline
mopar65  Offline
Jeff
Jeff thanks for the info. so will these work?
http://www.ebay.com/itm/Metric-Brake-Cal...959&vxp=mtr
also do you have the measurements on wear the brackets get welded on? sorry for the high jack of your post. i have been wanting to do something like this for a long time to my dart. thanks Bobby
Re: GM metric rear disc conversion [Re: mopar65] #1313399
09/30/12 09:52 PM
09/30/12 09:52 PM
MN
MN
That is the bracket you will need. As for where it gets welded, that depends on the rotor used. From what I can tell the hat of the Jeep rotor is deeper then the Explorer rotor. That will change the location of the caliper, and where the mounting bracket is located.
Jeff
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313400
09/30/12 09:57 PM
09/30/12 09:57 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
speedway motors sell the kit..
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313401
09/30/12 10:04 PM
09/30/12 10:04 PM
mopar65 Offline
mopar65  Offline
Jeff
well i guess i will wait and see which rotor you use.lol also i think you have a dana 60 in your car right? my car has a 8-3/4 with moser axles and green bearings. so i wonder if the measurements would be in the same place? probably not just asking. also what do you do about the backing plates for the drum breaks? i mean can you just pull them off and bolt the axle back to the axle housing?? sorry for all the questions.Bobby
Re: GM metric rear disc conversion [Re: mopar65] #1313402
09/30/12 10:06 PM
09/30/12 10:06 PM
MN
MN
I do have a Dana60 in my car, but it should not matter Dana or 8 3/4. Yes the drum backing plates are removed, and the axle bolts right back in place.
Re: GM metric rear disc conversion [Re: earthmover] #1313403
09/30/12 10:11 PM
09/30/12 10:11 PM
mopar65 Offline
mopar65  Offline
hey got a link?? thanks Bobby
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313404
09/30/12 10:17 PM
09/30/12 10:17 PM
mopar65 Offline
mopar65  Offline
OK Jeff hurry up and get yours done so i can start on mine.lol wow i cant b-leave how cheep Chevy parts are.
http://www.oreillyauto.com/site/c/detail...5&ppt=C0066
looks like this might end up costing less that i thought. also if you go with the jeep rotors what year would use and last question what are you going to do for break lines for the back. i mean wear the line hooks up to the caliper. thanks for the help Jeff. Bobby
Re: GM metric rear disc conversion [Re: mopar65] #1313405
09/30/12 10:23 PM
09/30/12 10:23 PM
MN
MN
I'll be buying parts for mine over the winter. No rush actually. As for lines, I saw on ebay someone had lines, and adapters, but not sure on the length.
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313406
09/30/12 10:28 PM
09/30/12 10:28 PM
mopar65 Offline
mopar65  Offline
well darn i don't want to wait all winter.lol sorry Jeff just joking.also what year jeep would you pick for the rotors? well looks like everything besides the brackets can be bought from the parts store. wonder why i didn't do this along time ago.lol. thanks Bobby
Re: GM metric rear disc conversion [Re: 440W8 Duster] #1313407
09/30/12 10:31 PM
09/30/12 10:31 PM
mopar65 Offline
mopar65  Offline
you wouldn't have a pic of your rear break set up would you? thanks Mopar65
Re: GM metric rear disc conversion [Re: mopar65] #1313408
09/30/12 10:37 PM
09/30/12 10:37 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Re: GM metric rear disc conversion [Re: earthmover] #1313409
09/30/12 10:41 PM
09/30/12 10:41 PM
MN
MN
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313410
09/30/12 10:52 PM
09/30/12 10:52 PM
mopar65 Offline
mopar65  Offline
Rotors
[url=http://www.ebay.com/itm/99-04-Jeep-Grand-Cherokee-Rear-Disc-Brake-Rotors-Left-Right-Pair-Set-of-2-NEW-/130766844749?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e724fb34d&vxp=mtr]http://www.ebay.com/
itm/99-04-Jeep-Grand...34d&vxp=mtr[/url]
jeff thanks fort he info. looks like you can get the same thing at slowrileys and i found the brake line kit in ebay or speedway catalog. also one more question and i will leave you a loan.lol my axles have 5/8 wheel studs so i can just drill the rotors out on a drill press right? thanks again bobby
Re: GM metric rear disc conversion [Re: earthmover] #1313411
09/30/12 10:53 PM
09/30/12 10:53 PM
mopar65 Offline
mopar65  Offline
this should get you there..
http://www.google.com/url?sa=t&rct=j...pWnLVzrwPfB2Dqw
thanks for the link. Bobby
Re: GM metric rear disc conversion [Re: mopar65] #1313412
09/30/12 11:43 PM
09/30/12 11:43 PM
San Antonio,TX
San Antonio,TX
Mopar65 yes you can drill for 5/8 studs.Jeff they also make a rotor with a 1/4 thick flange and a 1/8 flange so if you dont have a long enough stud you might get the thinner ones.
70 Duster W8 motor.
@3170 lbs.
Re: GM metric rear disc conversion [Re: 440W8 Duster] #1313413
09/30/12 11:56 PM
09/30/12 11:56 PM
mopar65 Offline
mopar65  Offline
hey thanks for the help. also do you have the parts numbers for the different thickness rotors or are the ones you are talking about not from the part store?? Thanks Bobby
Page 1 of 3 1 2 3
