GM metric rear disc conversion
#1313394
09/30/12 08:57 PM
09/30/12 08:57 PM
Posts: 10,037 MN
JERICOGTX
MN
For those that have done the GM metric caliper rear disc conversion, what rotors are you using? Those from a Jeep or Ford Explorer?
Thanks.
Jeff
69 GTX
68 Road Runner
Re: GM metric rear disc conversion
[Re: JERICOGTX]
#1313397
09/30/12 09:24 PM
09/30/12 09:24 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Jeff I used rotors from a Jeep Grand Cherokee with GM metric calipers and brakes from any circle track shop for the rear.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: mopar65]
#1313408
09/30/12 10:37 PM
09/30/12 10:37 PM
Posts: 2,449 nc
earthmover
nc
[Re: earthmover]
#1313409
09/30/12 10:41 PM
09/30/12 10:41 PM
Posts: 10,037 MN
JERICOGTX
MN
[Re: mopar65]
#1313412
09/30/12 11:43 PM
09/30/12 11:43 PM
440W8 Duster
San Antonio,TX
Mopar65 yes you can drill for 5/8 studs.Jeff they also make a rotor with a 1/4 thick flange and a 1/8 flange so if you dont have a long enough stud you might get the thinner ones.
